Is fport=null the correct behavior?
Viewed 9
HI,
Since older ABP end devices don't support MAC commands, I configured the following settings.
  • chirpstack.toml configuration
[network]
  mac_commands_disabled=true
However, looking at the logs, we see downlink packets with fport=null set like this.
Is this the correct behavior?
    "phy_payload": {
        "mhdr": {
            "f_type": "UnconfirmedDataDown",
            "major": "LoRaWANR1"
        "mic": [
            178,
            106,
            50,
            213
        "payload": {
            "f_port": null,  <- correct??
            "fhdr": {
                "devaddr": "ff00ead2",
                "f_cnt": 1013,
                "f_ctrl": {
                    "ack": false,
                    "adr": false,
                    "adr_ack_req": false,
                    "class_b": false,
                    "f_opts_len": 0,
                    "f_pending": false
                "f_opts": []
            "frm_payload": null
thank you,
Please add the preceding uplink to your question, that might clarify the empty downlink.
It provides pairs of uplink and downlink data. Is this because some control is being performed, making fport=null?
"phy_payload": {
"mhdr": {
"mic": [
69,
66,
74,
115
"payload": {
"f_port": null,
"fhdr": {
"f_cnt": 1089,
"f_ctrl": {
"ack": false,
"adr": false,
"class_b": false,
"f_opts_len": 0,
"f_pending": false
"f_opts": []
"frm_payload": null
"tx_info": {
"context": "qwn55A==",
"frequency": 923000000,
"modulation": {
"lora": {
"bandwidth": 125000,
"codeRate": "CR_4_5",
"polarizationInversion": true,
"spreadingFactor": 7
"power": 16,
"timing": {
"delay": {
"delay": "1s"
"phy_payload": {
"mhdr": {
"f_type": "UnconfirmedDataUp",
"mic": [
170,
71,
114,
251
"payload": {
"f_port": 1,
"fhdr": {
"f_cnt": 60061,
"f_ctrl": {
"ack": false,
"adr": true,
"adr_ack_req": true,
"class_b": false,
"f_opts_len": 0,
"f_pending": false
"f_opts": []
"frm_payload": "4d64000005b641e3377dff"
"rx_info": [
"channel": 5,
"crcStatus": "CRC_OK",
"gatewayId": "7276ff0045060159",
"gwTime": "2026-07-09T15:07:33.058859+00:00",
"location": {},
"nsTime": "2026-07-09T15:07:33.093169213+00:00",
"rssi": -63,
"snr": 8.800000190734863,
"uplinkId": 54691
"tx_info": {
"modulation": {
"lora": {
