Use of Tektelic 64-channel gateway
Viewed 27
Good afternoon, team.
I need a little guidance on the correct use of TomL files when using 64-channel gateways.
The TomL files explain that to listen to all gateway channels, I need to change this to # enabled_uplink_channels=[].. However, when I do this, the downlinks stop working.
They are created in the queue but never sent.
I also noticed that it doesn't matter if I limit it to 8 channels with enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7, 64]; it continues to use all its channels and sends me uplinks using channels 36 and 18. Sometimes the channel doesn't appear, but the uplink still arrives.
The enabled_uplink_channels is used to compute the correct CFList that is sent as part of the join-accept and / or the LinkADRReq.
Depending the mac-version and region, the channel-mask is only sent after the join-accept (the most recent versions have it included in the join-accept). Until the device confirms the CFList in the LinkADRReq mac-command, ChirpStack will use all channels.
Correct, it should use all channels. If this does not work, check the logs and / or GW <> ChirpStack communication. It might be that the gateway rejects the downlink for an other reason.
I've run several tests making changes to the TOML file, but they only send downlinks when I use the following configuration:
I used this to see if I needed to declare all the channels:
enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 41] 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64
ChirpStack MQTT Forwarder logs:
But it didn't work; after changing this, it doesn't send a downlink.
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2155728135, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 52487, remote: 127.0.0.1:52818
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 52487, remote: 127.0.0.1:52818, error:
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2155728135, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2969998448, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 38000, remote: 127.0.0.1:52818
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 38000, remote: 127.0.0.1:52818, error:
Jun 22 15:22:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2969998448, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 36964, remote: 127.0.0.1:59719
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 36964 remote: 127.0.0.1:59719
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3648085498, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 21835, remote: 127.0.0.1:59719
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 21835 remote: 127.0.0.1:59719
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3965071552, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PULL_DATA received, random_token: 44545, remote: 127.0.0.1:52818
Jun 22 15:22:36 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_ACK, random_token: 44545, remote: 127.0.0.1:52818
Jun 22 15:22:37 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 62868, remote: 127.0.0.1:59719
Jun 22 15:22:37 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 62868 remote: 127.0.0.1:59719
Jun 22 15:22:37 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 2670310334, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:38 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 62734, remote: 127.0.0.1:59719
Jun 22 15:22:38 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 62734 remote: 127.0.0.1:59719
Jun 22 15:22:38 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 738150312, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 10470, remote: 127.0.0.1:59719
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 10470 remote: 127.0.0.1:59719
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3994790783, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 30857, remote: 127.0.0.1:59719
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 30857 remote: 127.0.0.1:59719
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 688904095, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 15303, remote: 127.0.0.1:59719
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 15303 remote: 127.0.0.1:59719
Jun 22 15:22:40 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3041191758, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 8545, remote: 127.0.0.1:59719
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 8545 remote: 127.0.0.1:59719
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3530837760, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 40899, remote: 127.0.0.1:59719
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 40899 remote: 127.0.0.1:59719
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3106293983, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 1898732447, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 23455, remote: 127.0.0.1:52818
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 23455, remote: 127.0.0.1:52818, error:
Jun 22 15:22:42 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 1898732447, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:43 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:43 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2269511999, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:43 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 319, remote: 127.0.0.1:52818
Jun 22 15:22:43 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 319, remote: 127.0.0.1:52818, error:
Jun 22 15:22:43 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2269511999, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 15777, remote: 127.0.0.1:59719
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 15777 remote: 127.0.0.1:59719
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 2919421846, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 979227182, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 53806, remote: 127.0.0.1:52818
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 53806, remote: 127.0.0.1:52818, error:
Jun 22 15:22:44 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 979227182, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 1490, remote: 127.0.0.1:59719
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 1490 remote: 127.0.0.1:59719
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3444698410, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2339661846, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 26646, remote: 127.0.0.1:52818
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 26646, remote: 127.0.0.1:52818, error:
Jun 22 15:22:45 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2339661846, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:46 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 32049, remote: 127.0.0.1:59719
Jun 22 15:22:46 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 32049 remote: 127.0.0.1:59719
Jun 22 15:22:46 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 944991778, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:46 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PULL_DATA received, random_token: 42513, remote: 127.0.0.1:52818
Jun 22 15:22:46 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_ACK, random_token: 42513, remote: 127.0.0.1:52818
Jun 22 15:22:47 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 38593, remote: 127.0.0.1:59719
Jun 22 15:22:47 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 38593 remote: 127.0.0.1:59719
Jun 22 15:22:47 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 145703380, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:47 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 9495, remote: 127.0.0.1:59719
Jun 22 15:22:47 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 9495 remote: 127.0.0.1:59719
Jun 22 15:22:47 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 1587082457, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:48 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 25126, remote: 127.0.0.1:59719
Jun 22 15:22:48 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 25126 remote: 127.0.0.1:59719
Jun 22 15:22:48 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3065630877, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 10107, remote: 127.0.0.1:59719
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 10107 remote: 127.0.0.1:59719
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3877224420, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2309948141, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 749, remote: 127.0.0.1:52818
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 749, remote: 127.0.0.1:52818, error:
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2309948141, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 3856, remote: 127.0.0.1:59719
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 3856 remote: 127.0.0.1:59719
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 2754564911, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 3869240504, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 60600, remote: 127.0.0.1:52818
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 60600, remote: 127.0.0.1:52818, error:
Jun 22 15:22:49 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 3869240504, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:50 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 7709, remote: 127.0.0.1:59719
Jun 22 15:22:50 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 7709 remote: 127.0.0.1:59719
Jun 22 15:22:50 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 1445930757, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:51 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 36167, remote: 127.0.0.1:59719
Jun 22 15:22:51 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 36167 remote: 127.0.0.1:59719
Jun 22 15:22:51 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 1060027127, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:51 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 3708, remote: 127.0.0.1:59719
Jun 22 15:22:51 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 3708 remote: 127.0.0.1:59719
Jun 22 15:22:51 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 1040102644, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:52 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:52 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2123760391, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:52 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 775, remote: 127.0.0.1:52818
Jun 22 15:22:52 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 775, remote: 127.0.0.1:52818, error:
Jun 22 15:22:52 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2123760391, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 35631, remote: 127.0.0.1:59719
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 35631 remote: 127.0.0.1:59719
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3812345253, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 812096080, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 39504, remote: 127.0.0.1:52818
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 39504, remote: 127.0.0.1:52818, error:
Jun 22 15:22:53 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 812096080, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 15:22:55 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 53372, remote: 127.0.0.1:59719
Jun 22 15:22:55 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 53372 remote: 127.0.0.1:59719
Error logs:
Jun 22 14:31:27 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 384440312, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:27 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 6136, remote: 127.0.0.1:52818
Jun 22 14:31:27 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 6136, remote: 127.0.0.1:52818, error:
Jun 22 14:31:27 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 384440312, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 14:31:28 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 45748, remote: 127.0.0.1:59719
Jun 22 14:31:28 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 45748 remote: 127.0.0.1:59719
Jun 22 14:31:28 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending gateway stats event, topic: au915_0/gateway/647fdafffe031823/event/stats
Jun 22 14:31:28 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 55658, remote: 127.0.0.1:59719
Jun 22 14:31:28 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 55658 remote: 127.0.0.1:59719
Jun 22 14:31:29 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 3521648321, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 14:31:29 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 14:31:29 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 3094483632, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:29 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 4784, remote: 127.0.0.1:52818
Jun 22 14:31:29 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 4784, remote: 127.0.0.1:52818, error:
Jun 22 14:31:29 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 3094483632, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 59138, remote: 127.0.0.1:59719
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 59138 remote: 127.0.0.1:59719
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 1939557922, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2152378074, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 44762, remote: 127.0.0.1:52818
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 44762, remote: 127.0.0.1:52818, error:
Jun 22 14:31:30 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2152378074, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 35242, remote: 127.0.0.1:59719
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 35242 remote: 127.0.0.1:59719
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 4225416926, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 2286465693, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 45725, remote: 127.0.0.1:52818
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 45725, remote: 127.0.0.1:52818, error:
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 2286465693, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 30982, remote: 127.0.0.1:59719
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 30982 remote: 127.0.0.1:59719
Jun 22 14:31:32 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 4005758110, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 104006305, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 673, remote: 127.0.0.1:52818
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 673, remote: 127.0.0.1:52818, error:
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 104006305, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 19917, remote: 127.0.0.1:59719
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 19917 remote: 127.0.0.1:59719
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 1304235219, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 3329207496, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 44232, remote: 127.0.0.1:52818
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: TX_ACK received, random_token: 44232, remote: 127.0.0.1:52818, error:
Jun 22 14:31:33 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending ack event, downlink_id: 3329207496, topic: au915_0/gateway/647fdafffe031823/event/ack
Jun 22 14:31:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PULL_DATA received, random_token: 14301, remote: 127.0.0.1:52818
Jun 22 14:31:34 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_ACK, random_token: 14301, remote: 127.0.0.1:52818
Jun 22 14:31:35 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: PUSH_DATA received, random_token: 56663, remote: 127.0.0.1:59719
Jun 22 14:31:35 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PUSH_ACK, random_token: 56663 remote: 127.0.0.1:59719
Jun 22 14:31:35 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending uplink event, uplink_id: 2440345178, topic: au915_0/gateway/647fdafffe031823/event/up
Jun 22 14:31:35 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received message, topic: au915_0/gateway/647fdafffe031823/command/down, qos: AtMostOnce
Jun 22 14:31:35 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Received downlink command, downlink_id: 3589389817, topic: au915_0/gateway/647fdafffe031823/command/down
Jun 22 14:31:35 kona-mega-031823 chirpstack-mqtt-forwarder[2566]: Sending PULL_RESP, random_token: 48633, remote: 127.0.0.1:52818
