InfluxDB v2 Integration Silently Stops Writing
Viewed 130
Environment
  • ChirpStack Version: 4.12
  • InfluxDB Version: v2
  • Integration: InfluxDB v2 (enabled at application level)
  • Device Type: LoRaWAN water meter (daily transmissions)
  • Device EUI: 8cf957200016a072
Problem Summary
We are looking at a device that stopped writing data to InfluxDB after October 16, 2025 at 17:46:17 UTC, despite:
  • The device continuing to send uplinks successfully
  • ChirpStack receiving and processing the uplinks normally
Observations from Logs
Last Successful Write (October 16, 2025 17:46:17 UTC)
The device had one successful uplink with the following log entry:
2025-10-16T17:46:17.409100Z  INFO chirpstack::integration::influxdb: Uplink measurements sent to InfluxDB dev_eui=8cf957200016a072
However, this uplink also generated a warning:
2025-10-16T17:46:17.396365Z  WARN chirpstack::maccommand: Handle mac-command error dev_eui=8cf957200016a072 cid=LinkADRAns error=Expected pending LinkADRReq mac-command
The device sent another uplink exactly 7 days later, which ChirpStack processed normally:
  • ✅ Uplink received and decoded
  • ✅ Metrics saved to Redis (instantaneous_flow_m3ph, reverse_cumulative_flow_m3, positive_cumulative_flow_m3)
  • ✅ MQTT integration published event to topic
  • ✅ Downlink frame sent (LinkADRReq)
  • NO "Uplink measurements sent to InfluxDB" log entry
InfluxDB Evidence
Direct inspection of InfluxDB logs shows:
  • Zero write attempts (POST /api/v2/write) for this device after October 16th
  • Only query operations (POST /api/v2/query) for reading existing data
  • Two write errors from ChirpStack on October 24th (different time, likely different device):
    status_code=400 error=invalid error_code=invalid
Key Details from CSV Analysis
The attached CSV shows the complete log sequence for both uplinks:
October 16 uplink (lines 5-118):
  • MAC command warning present
  • Full metrics processing chain executed
  • InfluxDB write logged successfully
October 23 uplink (lines 119-266):
  • No MAC command warnings
  • MQTT event published
  • InfluxDB write NOT logged (silent failure)
What We've Verified
  1. ✅ Device is transmitting regularly (7-day interval)
  2. ✅ ChirpStack receives and processes uplinks
  3. ✅ Payload decoder executes (metrics are saved to Redis)
  4. ✅ InfluxDB integration is enabled for the application
  5. ✅ InfluxDB is running and accepting queries
  6. ✅ Other devices in same application write successfully
  7. ❌ This specific device stopped writing with no error logs
Additional Context
  • ChirpStack service restarted on October 23rd at 18:18 UTC (after the 17:46 uplink)
  • InfluxDB has been running continuously since September 25th
  • The device's last successful data point in InfluxDB shows positive_cumulative_flow_m3 = 0.752 on October 16th at 18:00 UTC
  • All subsequent uplinks are processed by ChirpStack but never reach InfluxDB
Attached: Complete log CSV showing both uplinks with timestamps and all processing steps for the above device.
https://limewire.com/d/fQ3Ft#pA0zMNZTkU
just captured errors for multiple devices
https://limewire.com/d/qNO6p#fxkpaJZn6z
all of them show the same behaviour I can see the measurements in chirsptack UI (redis) but not in influxdb
BUG FOUND: It was due to some redis problem, it is now fixed
