Managed Chirpstack Services
Viewed 73
Hello community,
Looking for recommendations on a managed ChirpStack.
Use case: ~20k Class A water meters, uplinks every 8–24 hrs. Numerous gateways spread over a large area.
Curious what people are running in similar scale and what made the decision clear for you.
Thanks!
I would like to avoid turning the support channel into a marketplace (people offering their hosted services). However, the question is if a managed ChirpStack instance is needed.
If your 20k device communicate every 8 hours ("worst case"), then this means less than 1 uplink / second (~ 0.7 msg / second). That is not much :-)
