Error during Chirpstack v3 to v4 migration : column "class_b_timeout" of relation "device_profile" does not exist
Viewed 155
Recently, installed ChirpStack v4 version 4.11.1 to migrate from ChirpStack v3 to v4.
(I see that the migration tool at https://github.com/chirpstack/chirpstack-v3-to-v4 is compatible with ChirpStack v4.11.x.)
After install ChirpStack v4, ran migration.
~/migration$ sudo ./chirpstack-v3-to-v4 \
        --cs-config-file /etc/chirpstack/chirpstack.toml \
        --as-config-file /etc/chirpstack-application-server/chirpstack-application-server.toml \
        --ns-config-file /etc/chirpstack-network-server/chirpstack-network-server.toml
2026/03/04 16:02:54 Reading ChirpStack configuration file: /etc/chirpstack/chirpstack.toml
2026/03/04 16:02:54 Reading AS configuration file: /etc/chirpstack-application-server/chirpstack-application-server.toml
2026/03/04 16:02:54 Start migration
2026/03/04 16:02:54 Migrating users
2026/03/04 16:02:54 Migrating organizations
2026/03/04 16:02:54 Migrating organization users
2026/03/04 16:02:54 Migrating applications
2026/03/04 16:02:54 Migrating application integrations
2026/03/04 16:02:54 Reading NS configuration file: /etc/chirpstack-network-server/chirpstack-network-server.toml
2026/03/04 16:02:54 Migrating region: KR920
2026/03/04 16:02:54 Migrating gateways
2026/03/04 16:02:54 Migrating gateway metrics
2026/03/04 16:02:54 Migrating device-profiles
2026/03/04 16:02:54 Prepare device-profile statement errorpq: column "class_b_timeout" of relation "device_profile" does not exist
It looks like an error occurred during the device-profiles migration process. And, When accessing the web UI and navigating to the Applications category, the Devices tab displays an error stating that the column "device_profiles.is_relay" does not exist.
How do I resolve errors that occur during device-profiles migration?
Any help is appreciated.
@brocaar Very Thank you! After deleting and resetting the Postgres chirpstack database and reinstalling chirpstack v4.11.1, the migration completed without errors. All previously registered profiles, gateways, and device information are displayed normally in the chirpstack v4 web UI.
Is chirpstack v4 compatible with chirpstack-gateway-bridge v3? If not, I plan to update the gateway bridge to v4 as well.
