i have a question regarding to DevAddr Prefix in de Chirpstack Configuration.
Regarding to this old post https://forum.chirpstack.io/t/is-the-device-address-automatically-generated-when-a-node-joins/10924/12 it is normal, to have dublicated devAddrs if you have many devices.
myself, i have about 10'000 Devices (with the plan to have arround 20'000) - and never had duplicated devAddrs. A few days ago i started with DevAddr Prefix /17 - which should give me arround 32'000 DevAddrs. Now i started rejoining the devices, and i have now a few duplicated devAddrs. Most used devAddr is used 11 times from different devices.
now my question:
- why should i use a devAddr Prefix with 32'000 Addresses, if they duplicate anyway?
- does it have any performance issues, when MIC is needed to find the correct Device?
- can i just use /24 (for example), so i have only 256 devAddrs. I will have a lot of duplicated devAddrs, but can filter a smaler range on the Gateways.
- whats the best practice for devAddr Prefix? should it be as high as planed devices, or not? what do you guys use there?
thanks for your feedback,
Sil
