ChirpStack Community Support
Questions Tags Users Badges
Error with Downlink to DS3604-Displays
Erik 1
Created Jan 21
Viewed 27
Anyone ever bumped into an error from downlinks that says the following?
Code: DOWNLINK_GATEWAY
Level: ERROR
description: GPS_UNLOCKED
There are 3 different gateways that should be able to send these downlinks. Two UG65-gateways and one Multitech MTCDTIP-L4E1-266A. We are getting the same error on three different Displays.
troubleshooting gateways chirpstack
Share
Related
Use of Tektelic 64-channel gateway
Invalid Length error in gateway menu after backup/restore..
Home Assistant Downstream MQTT connections to LT-22222-L
ChirpStack MQTT gateway reconnect issue after gateway reboot
MKR WAN 1310 + RAK2243 + ChirpStack 4.18: uplinks reach server, downlinks not reaching device (was working, now failing)
Update issue: ChirpStack v4.15 -> v4.18
Terms of service Privacy policy
Powered by Answer
