Issues connecting MultiTech GW with Gateway-Bridge (Basic Station)
Viewed 60
I'm trying to connect a MultiTech MTCDT GW running in Basic Station mode to a Chirpstack-Gateway-Bridge, running on a Debian machine. For testing I'm running without certificates at all, and thus want to connect via ws://.
However, I get an error when trying to run the Basic Station, as it complains about the "routerid" being set to an illegal EUI. It seems to stem from the "routerid": "" line not being overwritten during startup. Any ideas what might be happening here, or what next steps I can do to troubleshoot? I'm attaching the chirpstack-gateway-bridge.toml and the station.conf from the gateway.
Gateway setup:
chirpstack-gateway-bridge.toml:
[general]
log_level=5
# Log in JSON format.
log_json=false
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=false
# Filters.
# These can be used to filter LoRaWAN frames to reduce bandwith usage between
# the gateway and ChirpStack Gateway Bridge. Depending the used backend, filtering
# will be performed by the Packet Forwarder or ChirpStack Gateway Bridge.
[filters]
# NetIDs filters.
# The configured NetIDs will be used to filter uplink data frames.
# When left blank, no filtering will be performed on NetIDs.
# Example:
# net_ids=[
#   "000000",
#   "000001",
net_ids=[
# JoinEUI filters.
# The configured JoinEUI ranges will be used to filter join-requests.
# When left blank, no filtering will be performed on JoinEUIs.
# Example:
# join_euis=[
#   ["0000000000000000", "00000000000000ff"],
#   ["000000000000ff00", "000000000000ffff"],
join_euis=[
[backend]
# Backend type.
# Valid options are:
#   * semtech_udp
#   * concentratord
#   * basic_station
type="basic_station"
  # Semtech UDP packet-forwarder backend.
  [backend.semtech_udp]
  # ip:port to bind the UDP listener to
  # Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
  # This is the listener to which the packet-forwarder forwards its data
  # so make sure the 'serv_port_up' and 'serv_port_down' from your
  # packet-forwarder matches this port.
  udp_bind = "0.0.0.0:1700"
  # Fake RX timestamp.
  # Fake the RX time when the gateway does not have GPS, in which case
  # the time would otherwise be unset.
  fake_rx_time=false
  # ChirpStack Concentratord backend.
  [backend.concentratord]
  # Event API URL.
  event_url="ipc:///tmp/concentratord_event"
  # Command API URL.
  command_url="ipc:///tmp/concentratord_command"
  # Basic Station backend.
  [backend.basic_station]
  # ip:port to bind the Websocket listener to.
  bind=":3001"
  # TLS certificate and key files.
  # When set, the websocket listener will use TLS to secure the connections
  # between the gateways and ChirpStack Gateway Bridge (optional).
  tls_cert=""
  tls_key=""
  # TLS CA certificate.
  # When configured, ChirpStack Gateway Bridge will validate that the client
  # certificate of the gateway has been signed by this CA certificate.
  ca_cert=""
  # Stats interval.
  # This defines the interval in which the ChirpStack Gateway Bridge forwards
  # the uplink / downlink statistics.
  stats_interval="30s"
  # Ping interval.
  ping_interval="1m0s"
  # Timesync interval.
  # This defines the interval in which the ChirpStack Gateway Bridge sends
  # a timesync request to the gateway. Setting this to 0 disables sending
  # timesync requests.
  timesync_interval="0s"
  # Read timeout.
  # This interval must be greater than the configured ping interval.
  read_timeout="1m5s"
  # Write timeout.
  write_timeout="1s"
  # Region.
  # Please refer to the LoRaWAN Regional Parameters specification
  # for the complete list of common region names.
  region="EU868"
  # Minimal frequency (Hz).
  frequency_min=863000000
  # Maximum frequency (Hz).
  frequency_max=870000000
  # Concentrator configuration.
  # This section contains the configuration for the SX1301 concentrator chips.
  # Example:
  # [[backend.basic_station.concentrators]]
  #   # Multi-SF channel configuration.
  #   [backend.basic_station.concentrators.multi_sf]
  #   # Frequencies (Hz).
  #   frequencies=[
  #     868100000,
  #     868300000,
  #     868500000,
  #     867100000,
  #     867300000,
  #     867500000,
  #     867700000,
  #     867900000,
  #   # LoRa STD channel.
  #   [backend.basic_station.concentrators.lora_std]
  #   # Frequency (Hz).
  #   frequency=868300000
  #   # Bandwidth (Hz).
  #   bandwidth=250000
  #   # Spreading factor.
  #   spreading_factor=7
  #   # FSK channel.
  #   [backend.basic_station.concentrators.fsk]
  #   # Frequency (Hz).
  #   frequency=868800000
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf:  Protobuf encoding
# * json:      JSON encoding (for debugging)
marshaler="protobuf"
  # MQTT integration configuration.
  [integration.mqtt]
  # Event topic template.
  event_topic_template="gateway/{{ .GatewayID }}/event/{{ .EventType }}"
  # State topic template.
  # States are sent by the gateway as retained MQTT messages (by default)
  # so that the last message will be stored by the MQTT broker. When set to
  # a blank string, this feature will be disabled. This feature is only
  # supported when using the generic authentication type.
  state_topic_template="gateway/{{ .GatewayID }}/state/{{ .StateType }}"
  # Command topic template.
  command_topic_template="gateway/{{ .GatewayID }}/command/#"
  # State retained.
  # By default this value is set to true and states are published as retained
  # MQTT messages. Setting this to false means that states will not be retained
  # by the MQTT broker.
  state_retained=true
  # Keep alive will set the amount of time (in seconds) that the client should
  # wait before sending a PING request to the broker. This will allow the client
  # to know that a connection has not been lost with the server.
  # Valid units are 'ms', 's', 'm', 'h'. Note that these values can be combined, e.g. '24h30m15s'.
  keep_alive="30s"
  # Maximum interval that will be waited between reconnection attempts when connection is lost.
  max_reconnect_interval="1m0s"
  # Terminate on connect error.
  # When set to true, instead of re-trying to connect, the ChirpStack Gateway Bridge
  # process will be terminated on a connection error.
  terminate_on_connect_error=false
  # MQTT authentication.
  [integration.mqtt.auth]
  # Type defines the MQTT authentication type to use.
  # Set this to the name of one of the sections below.
  type="generic"
    # Generic MQTT authentication.
    # MQTT servers.
    # Configure one or multiple MQTT server to connect to. Each item must be in
    # the following format: scheme://host:port where scheme is tcp, ssl or ws.
    servers=[
      "tcp://127.0.0.1:1883",
    username=""
    password=""
    # Quality of service level
    # 0: at most once
    # 1: at least once
    # 2: exactly once
    qos=0
    # Clean session
    clean_session=true
    # Client ID
    client_id=""
    ca_cert=""
    # mqtt TLS certificate file (optional)
    tls_cert=""
    # mqtt TLS key file (optional)
    tls_key=""
    # Google Cloud Platform Cloud IoT Core authentication.
    # Please note that when using this authentication type, the MQTT topics
    # will be automatically set to match the MQTT topics as expected by
    # Cloud IoT Core.
    [integration.mqtt.auth.gcp_cloud_iot_core]
    # MQTT server.
    server="ssl://mqtt.googleapis.com:8883"
    # Google Cloud IoT Core Device id.
    device_id=""
    # Google Cloud project id.
    project_id=""
    # Google Cloud region.
    cloud_region=""
    # Google Cloud IoT registry id.
    registry_id=""
    # JWT token expiration time.
    jwt_expiration="24h0m0s"
    # JWT token key-file.
    # Example command to generate a key-pair:
    #  $ ssh-keygen -t rsa -b 4096 -f private-key.pem
    #  $ openssl rsa -in private-key.pem -pubout -outform PEM -out public-key.pem
    # Then point the setting below to the private-key.pem and associate the
    # public-key.pem with this device / gateway in Google Cloud IoT Core.
    jwt_key_file=""
    # Azure IoT Hub
    # This setting will preset uplink and downlink topics that will only
    # work with Azure IoT Hub service.
    [integration.mqtt.auth.azure_iot_hub]
    # Device connection string (symmetric key authentication).
    # This connection string can be retrieved from the Azure IoT Hub device
    # details when using the symmetric key authentication type.
    device_connection_string=""
    # Token expiration (symmetric key authentication).
    # ChirpStack Gateway Bridge will generate a SAS token with the given expiration.
    # After the token has expired, it will generate a new one and trigger a
    # re-connect (only for symmetric key authentication).
    sas_token_expiration="24h0m0s"
    # Device ID (X.509 authentication).
    # This will be automatically set when a device connection string is given.
    # It must be set for X.509 authentication.
    device_id=""
    # IoT Hub hostname (X.509 authentication).
    # Example: iot-hub-name.azure-devices.net
    hostname=""
    # Client certificates (X.509 authentication).
    # Configure the tls_cert (certificate file) and tls_key (private-key file)
    # when the device is configured with X.509 authentication.
    tls_cert=""
    tls_key=""
# Metrics configuration.
[metrics]
  # Metrics stored in Prometheus.
  # These metrics expose information about the state of the ChirpStack Gateway Bridge
  # instance like number of messages processed, number of function calls, etc.
  [metrics.prometheus]
  # Expose Prometheus metrics endpoint.
  endpoint_enabled=false
  # The ip:port to bind the Prometheus metrics server to for serving the
  # metrics endpoint.
  bind=""
# Gateway meta-data.
# The meta-data will be added to every stats message sent by the ChirpStack Gateway
# Bridge.
[meta_data]
  # Static.
  # Static key (string) / value (string) meta-data.
  [meta_data.static]
  # Example:
  # serial_number="A1B21234"
  # Dynamic meta-data.
  # Dynamic meta-data is retrieved by executing external commands.
  # This makes it possible to for example execute an external command to
  # read the gateway temperature.
  [meta_data.dynamic]
  # Execution interval of the commands.
  execution_interval="1m0s"
  # Max. execution duration.
  max_execution_duration="1s"
  # Split delimiter.
  # When the output of a command returns multiple lines, ChirpStack Gateway Bridge
  # assumes multiple values are returned. In this case it will split by the given delimiter
  # to obtain the key / value of each row. The key will be prefixed with the name of the
  # configured command.
  split_delimiter="="
  # Commands to execute.
  # The value of the stdout will be used as the key value (string).
  # In case the command failed, it is ignored. In case the same key is defined
  # both as static and dynamic, the dynamic value has priority (as long as the)
  # command does not fail.
  [meta_data.dynamic.commands]
  # Example:
  # temperature="/opt/gateway-temperature/gateway-temperature.sh"
# Executable commands.
# The configured commands can be triggered by sending a message to the
# ChirpStack Gateway Bridge.
[commands]
  # Example:
  # [commands.commands.reboot]
  # max_execution_duration="1s"
  # command="/usr/bin/reboot"
station.conf (from GW):
  "SX1301_conf": {
    "lorawan_public": false,
    "clksrc": 0,
    "pps": true,
    "device": "/dev/spidev0.0",
    "chan_FSK": {"bandwidth": 125000, "datarate": 50000, "enable": true, "if": 300000, "radio": 0},
    "chan_Lora_std": {"bandwidth": 250000, "enable": true, "if": -200000, "radio": 0, "spread_factor": 7},
    "chan_multiSF_0": {"enable": true, "if": -400000, "radio": 0},
    "chan_multiSF_1": {"enable": true, "if": -200000, "radio": 0},
    "chan_multiSF_2": {"enable": true, "if": 0, "radio": 0},
    "chan_multiSF_3": {"enable": true, "if": -400000, "radio": 1},
    "chan_multiSF_4": {"enable": true, "if": -200000, "radio": 1},
    "chan_multiSF_5": {"enable": true, "if": 0, "radio": 1},
    "chan_multiSF_6": {"enable": true, "if": 200000, "radio": 1},
    "chan_multiSF_7": {"enable": true, "if": 400000, "radio": 1},
    "radio_0": {"enable": true, "freq": 868500000, "rssi_offset": -162, "tx_enable": true, "type": "SX1257"},
    "radio_1": {"enable": true, "freq": 868500000, "rssi_offset": -162, "tx_enable": false, "type": "SX1257"},
    "tx_gain_lut": [
      {"dig_gain": 0, "mix_gain": 11, "pa_gain": 0, "dac_gain": 3, "rf_power": -6},
      {"dig_gain": 0, "mix_gain": 13, "pa_gain": 0, "dac_gain": 3, "rf_power": -3},
      {"dig_gain": 0, "mix_gain": 9, "pa_gain": 1, "dac_gain": 3, "rf_power": 0},
      {"dig_gain": 0, "mix_gain": 10, "pa_gain": 1, "dac_gain": 3, "rf_power": 3},
      {"dig_gain": 0, "mix_gain": 12, "pa_gain": 1, "dac_gain": 3, "rf_power": 6},
      {"dig_gain": 0, "mix_gain": 10, "pa_gain": 2, "dac_gain": 3, "rf_power": 10},
      {"dig_gain": 0, "mix_gain": 11, "pa_gain": 2, "dac_gain": 3, "rf_power": 11},
      {"dig_gain": 0, "mix_gain": 11, "pa_gain": 2, "dac_gain": 3, "rf_power": 12},
      {"dig_gain": 2, "mix_gain": 12, "pa_gain": 2, "dac_gain": 3, "rf_power": 13},
      {"dig_gain": 0, "mix_gain": 13, "pa_gain": 2, "dac_gain": 3, "rf_power": 14},
      {"dig_gain": 0, "mix_gain": 15, "dac_gain": 3, "pa_gain": 2, "rf_power": 16},
      {"dig_gain": 0, "mix_gain": 10, "pa_gain": 3, "dac_gain": 3, "rf_power": 20},
      {"dig_gain": 0, "mix_gain": 12, "dac_gain": 3, "pa_gain": 3, "rf_power": 23},
      {"dig_gain": 0, "dac_gain": 3, "mix_gain": 13, "pa_gain": 3, "rf_power": 25},
      {"dig_gain": 0, "dac_gain": 3, "mix_gain": 15, "pa_gain": 3, "rf_power": 26},
      {"dig_gain": 0, "mix_gain": 15, "dac_gain": 3, "pa_gain": 3, "rf_power": 27}
  "station_conf": {
    "routerid": "<WILL-BE-AUTO-REPLACED-WITH-LORA-EUI>",
    "euiprefix": "::0",
    "log_file": "stderr",
    "log_level": "INFO",
    "log_size": 100000,
    "log_rotate": 3,
    "TC_TIMEOUT": "2s"
