Class-B devices stays at deviceClassEnabled: CLASS_A
Viewed 72
Hello!
Current Configuration on both sensor and Chirpstack:
Class-B Confirmed Donlink tiemout: 0
Class-B-ping-slot-datat-rate: 0
Class-B-ping-slot-periodicity: 16 seconds
Freq: 869525000(Hz)
Eventhough I've configured it as a Class-B sensor, chirpstack keeps returning 'deviceClassEnabled:"CLASS_A"'. Does anyone know why?
It works perfectly with downlinks, but an hour after configuring the sensor it stops responding to downlinks in queue.
Even if the device is configured as Class-B device within ChirpStack, it remains in Class-A until the device has aquired a Class-B beacon lock.
This often works as follows:
  • The device activates
  • It requests the time (e.g. DeviceTimeReq)
  • Using that time, it knows (with some error margin) when the next Class-B beacon is sent
  • Once it receives the Class-B beacon, it has aquired a more precise time
  • On the next uplink, it will set the Class-B bit, indicating to the network that is now able to receive Class-B downlinks
I see. Though it doesn't change after a while either. After configuring the device it just gives up after a while and stops sending uplinks to the platform as if it's a Class A sensor, which it displays in the uplinks. I've had the same problem with multicast-downlinks.
The idea is to have a presence-sensor report it's status to chirpstack which makes the display show presence-status through downlinks changing between template 1 and 2 to display respective presence status.
