RX1 window timeout when using RAK MQTT Forwarder for ChirpStack v4
3
Viewed 137
Hello folks.
I am trying to connect LoRa device using RAK7268CV2 gateway as forwarder but get 95 error code (Time out reached while waiting for a packet in the LoRa RX1 window: https://docs.rakwireless.com/product-categories/wisduo/rak4270-module/at-command-manual/#error-code-table ) using chirpstack v4. However, this device connects successfully with chirpstack v3.
Here is the logs:
Chirpstack:
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.691818Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/up qos=AtMostOnce json=false
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.893807Z  INFO up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}: chirpstack::uplink: Uplink received f_type=JoinRequest
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.893860Z DEBUG up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.894437Z DEBUG up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}: chirpstack::uplink: Logging uplink frame to Redis Stream
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.902187Z  INFO up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}:join_request{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::device_keys: Device-nonce validated, join-nonce incremented and stored dev_eui=bcfcc644f909e65c dev_nonce=60908
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.902744Z  INFO up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}:join_request{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::device_queue: Device queue flushed dev_eui=bcfcc644f909e65c count=0
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.908433Z  INFO up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}:join_request{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::device: Device partially updated dev_eui=bcfcc644f909e65c
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.908775Z  INFO up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}:join_request{dev_eui="bcfcc644f909e65c"}:join_accept{downlink_id=2055986882}: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=2055986882
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.908982Z  INFO up{deduplication_id=7701524b-6637-42fc-b348-229294c51901}:join_request{dev_eui="bcfcc644f909e65c"}:join_accept{downlink_id=2055986882}: chirpstack::gateway::backend::mqtt: Sending downlink frame region_id=eu868 gateway_id=ac1f09fffe18503d topic=eu868/gateway/ac1f09fffe18503d/command/down json=false
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.909707Z  INFO chirpstack::integration::mqtt: Publishing event topic=application/00000000-0000-0000-0000-000000000001/device/bcfcc644f909e65c/event/join
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.953472Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/ack qos=AtMostOnce json=false
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.953943Z  INFO tx_ack{downlink_id=2055986882}: chirpstack::downlink::tx_ack: Log downlink-frame for gateway gateway_id=ac1f09fffe18503d
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.954432Z  INFO tx_ack{downlink_id=2055986882}: chirpstack::downlink::tx_ack: Log downlink-frame for device device_eui=bcfcc644f909e65c
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.970579Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/ack qos=AtMostOnce json=false
Dec 11 09:51:20 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:20.970848Z ERROR chirpstack::downlink::tx_ack: Handling tx ack error error=Object does not exist (id: 2055986882)
Dec 11 09:51:25 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:25.927762Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/up qos=AtMostOnce json=false
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.130162Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}: chirpstack::uplink: Uplink received f_type=ConfirmedDataUp
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.130207Z DEBUG up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.130643Z DEBUG up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}: chirpstack::uplink: Logging uplink frame to Redis Stream
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.141232Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=bcfcc644f909e65c
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.166295Z  INFO chirpstack::integration::mqtt: Publishing event topic=application/00000000-0000-0000-0000-000000000001/device/bcfcc644f909e65c/event/up
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.175966Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::device: Device partially updated dev_eui=bcfcc644f909e65c
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.176089Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::metrics: Metrics saved name=device:bcfcc644f909e65c aggregation=HOUR
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.176143Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::metrics: Metrics saved name=device:bcfcc644f909e65c aggregation=DAY
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.176192Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}: chirpstack::storage::metrics: Metrics saved name=device:bcfcc644f909e65c aggregation=MONTH
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.278299Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::storage::mac_command: Pending mac-command block set cid=DevStatusReq
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.278318Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::storage::mac_command: Pending mac-command block set cid=PingSlotChannelReq
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.278336Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::storage::mac_command: Pending mac-command block set cid=DevStatusReq
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.278342Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::storage::mac_command: Pending mac-command block set cid=PingSlotChannelReq
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.278544Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=1664739085
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.286709Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::storage::device: Device partially updated dev_eui=bcfcc644f909e65c
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.286887Z  INFO up{deduplication_id=b7a2d230-38a1-438a-b8d1-4898e33b6311}:data_up{dev_eui="bcfcc644f909e65c"}:data_down{downlink_id=1664739085}: chirpstack::gateway::backend::mqtt: Sending downlink frame region_id=eu868 gateway_id=ac1f09fffe18503d topic=eu868/gateway/ac1f09fffe18503d/command/down json=false
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.328328Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/ack qos=AtMostOnce json=false
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.330361Z  INFO chirpstack::integration::mqtt: Publishing event topic=application/00000000-0000-0000-0000-000000000001/device/bcfcc644f909e65c/event/log
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.345809Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/ack qos=AtMostOnce json=false
Dec 11 09:51:26 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:26.346067Z ERROR chirpstack::downlink::tx_ack: Handling tx ack error error=Object does not exist (id: 1664739085)
Dec 11 09:51:33 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:33.847968Z  INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/ac1f09fffe18503d/event/stats qos=AtMostOnce json=false
Dec 11 09:51:33 devtankhq-trixie chirpstack[1302]: 2025-12-11T09:51:33.854111Z  INFO stats{gateway_id=ac1f09fffe18503d}: chirpstack::storage::gateway: Gateway partially updated gateway_id=ac1f09fffe18503d
Gateway:
Thu Dec 11 09:51:19 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:19 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:2788:fetch_packets():  Current time: 2025-12-11 09:51:20 UTC
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 376 uplinkTqByAirtime : dr = 4, timeonair = 102, tm = 1765446680
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 378 uplinkTqByPkt : dr = 4,  tm = 1765446680
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 380 ChanBusyByAirtime chan 4, timeonair = 102, tm = 1765446680
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: INFO: Received pkt CRC BAD
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 380 ChanBusyByAirtime chan 6, timeonair = 102, tm = 1765446680
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: INFO: [filter] white list join filter is not enable
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]:  INFO: Received pkt from mote: F909E65C (fcnt=64710)
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: Uplink Frame :
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	00 5C E6 09 F9 44 C6 FC
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	BC 5C E6 09 F9 44 C6 FC
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	BC EC ED CD 18 D8 04
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:3369:thread_up(): nb_pkt 1 send_report 0
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:3243:dgram_push_pkt(): buff_index 225 buff_size 8169
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]:  JSON up: {"rxpk":[{"jver":1,"tmst":3664778052,"chan":6,"rfch":1,"freq":868.300000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","rssis":-30
,"lsnr":15.0,"foff":-61,"rssi":-29,"size":23,"data":"AFzmCflExvy8XOYJ+UTG/Lzs7c0Y2AQ="}]}
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 248
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 248
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: Uplink - {"rxpk":[{"jver":1,"tmst":3664778052,"chan":6,"rfch":1,"freq":868.300000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","rssis":-30,"l
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: [Uplink] - Protobuf size 130
Thu Dec 11 09:51:20 2025 daemon.info mqttEv[8423]: mqttEvPublish : [[gwBridgeS Mqtt Client]] publish - [130][ W]
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: INFO: [up] PUSH_ACK received in 4 ms
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: mosqMsgCB topic : eu868/gateway/ac1f09fffe18503d/command/down
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: gwBridgeParseMosqDownlink mqtt downlink packet - size 174
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_RESP received  - token[194:222] :)
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]:  JSON down: {"txpk":{"imme":false,"tmst":3669778052,"freq":868.300000,"rfch":0,"powe":16,"ncrc":false,"modu":"LORA","codr":"4/5","datr":"SF8BW125","ipol":tru
e,"size":33,"data":"IMBr+hb2VS72gRnVB1X2XJvYtqCYfzKkrNdPRDDgh29x"}}
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: DownLink Frame :
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	20 C0 6B FA 16 F6 55 2E
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	F6 81 19 D5 07 55 F6 5C
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	9B D8 B6 A0 98 7F 32 A4
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	AC D7 4F 44 30 E0 87 6F
Thu Dec 11 09:51:20 2025 user.debug lora_pkt_fwd[8546]: 	71
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]: INFO: Packet ENQUENUE SUCCESS on SX1301/SX1302: 0
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:20 2025 user.info lora_pkt_fwd[8546]:  JSON down: {"txpk":{"imme":false,"tmst":3670778052,"freq":869.525000,"rfch":0,"powe":29,"ncrc":false,"modu":"LORA","codr":"4/5","datr":"SF12BW125","ipol":tr
ue,"size":33,"data":"IMBr+hb2VS72gRnVB1X2XJvYtqCYfzKkrNdPRDDgh29x"}}
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:20 2025 daemon.info gwBridge[8423]: [TxAck] - Protobuf size 28
Thu Dec 11 09:51:20 2025 daemon.info mqttEv[8423]: mqttEvPublish : [[gwBridgeS Mqtt Client]] publish - [28][P½¯ÔG*A2Pac1f09fffe18503d0àoq]
Thu Dec 11 09:51:20 2025 user.warn lora_pkt_fwd[8546]: WARNING: Requested TX power is not supported (29dBm), actual power used: 27dBm
Thu Dec 11 09:51:20 2025 daemon.info mqttEv[8423]: mqttEvPublish : [[gwBridgeS Mqtt Client]] publish - [28][P½¯ÔG*A2Pac1f09fffe18503d]
Thu Dec 11 09:51:21 2025 user.debug lora_pkt_fwd[8546]: PPS check: pps_xticks=0, last_pps_xticks=0, pps_nochange_count=59481, local_pps_ok=0
Thu Dec 11 09:51:24 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:24 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:24 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:24 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: DEBUG: peek packet with count_us=3669778052 at index 0
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:4535:thread_jit(): lgw_send done on rf_chain 0: count_us=3669778052
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:2788:fetch_packets():  Current time: 2025-12-11 09:51:25 UTC
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 376 uplinkTqByAirtime : dr = 4, timeonair = 72, tm = 1765446685
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 378 uplinkTqByPkt : dr = 4,  tm = 1765446685
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: rrd_statistic_up 380 ChanBusyByAirtime chan 6, timeonair = 72, tm = 1765446685
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]:  INFO: Received pkt from mote: 00E09535 (fcnt=0)
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: Uplink Frame :
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: 	80 35 95 E0 00 00 00 00
Thu Dec 11 09:51:25 2025 user.debug lora_pkt_fwd[8546]: 	7F 9F CA AF
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:3369:thread_up(): nb_pkt 1 send_report 0
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:3243:dgram_push_pkt(): buff_index 209 buff_size 8169
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]:  JSON up: {"rxpk":[{"jver":1,"tmst":3670030023,"chan":6,"rfch":1,"freq":868.300000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","rssis":-30
,"lsnr":14.0,"foff":-61,"rssi":-29,"size":12,"data":"gDWV4AAAAAB/n8qv"}]}
Thu Dec 11 09:51:25 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 232
Thu Dec 11 09:51:25 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 232
Thu Dec 11 09:51:25 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:25 2025 daemon.info gwBridge[8423]: Uplink - {"rxpk":[{"jver":1,"tmst":3670030023,"chan":6,"rfch":1,"freq":868.300000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","rssis":-30,"l
Thu Dec 11 09:51:25 2025 daemon.info gwBridge[8423]: [Uplink] - Protobuf size 119
Thu Dec 11 09:51:25 2025 daemon.info mqttEv[8423]: mqttEvPublish : [[gwBridgeS Mqtt Client]] publish - [119][ L5à]
Thu Dec 11 09:51:25 2025 user.info lora_pkt_fwd[8546]: INFO: [up] PUSH_ACK received in 0 ms
Thu Dec 11 09:51:26 2025 daemon.info gwBridge[8423]: mosqMsgCB topic : eu868/gateway/ac1f09fffe18503d/command/down
Thu Dec 11 09:51:26 2025 daemon.info gwBridge[8423]: gwBridgeParseMosqDownlink mqtt downlink packet - size 144
Thu Dec 11 09:51:26 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_RESP received  - token[13:231] :)
Thu Dec 11 09:51:26 2025 user.info lora_pkt_fwd[8546]:  JSON down: {"txpk":{"imme":false,"tmst":3671030023,"freq":868.300000,"rfch":0,"powe":16,"ncrc":false,"modu":"LORA","codr":"4/5","datr":"SF8BW125","ipol":tru
e,"size":18,"data":"YDWV4ACmAAAGEQAAAAOTeNlS"}}
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: DownLink Frame :
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: 	60 35 95 E0 00 A6 00 00
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: 	06 11 00 00 00 03 93 78
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: 	D9 52
Thu Dec 11 09:51:26 2025 user.info lora_pkt_fwd[8546]: src/jitqueue.c:282:jit_enqueue(): ERROR: Packet (type=0) REJECTED, collision with packet already programmed at 3670778052 (3671030023)
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: [logger]: pkt type = COLLISION_PACKET, count_us = 3671030023
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]:  JSON tx_ack: {"txpk_ack":{"error":"COLLISION_PACKET"}}
Thu Dec 11 09:51:26 2025 user.info lora_pkt_fwd[8546]:  JSON down: {"txpk":{"imme":false,"tmst":3672030023,"freq":869.525000,"rfch":0,"powe":29,"ncrc":false,"modu":"LORA","codr":"4/5","datr":"SF12BW125","ipol":tr
ue,"size":18,"data":"YDWV4ACmAAAGEQAAAAOTeNlS"}}
Thu Dec 11 09:51:26 2025 user.warn lora_pkt_fwd[8546]: WARNING: Requested TX power is not supported (29dBm), actual power used: 27dBm
Thu Dec 11 09:51:26 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 53
Thu Dec 11 09:51:26 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 53
Thu Dec 11 09:51:26 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:26 2025 daemon.info gwBridge[8423]: [TxAck] - Protobuf size 28
Thu Dec 11 09:51:26 2025 user.info lora_pkt_fwd[8546]: src/jitqueue.c:282:jit_enqueue(): ERROR: Packet (type=0) REJECTED, collision with packet already programmed at 3670778052 (3672030023)
Thu Dec 11 09:51:26 2025 daemon.info mqttEv[8423]: mqttEvPublish : [[gwBridgeS Mqtt Client]] publish - [28][PÎçF*D2Pac1f09fffe18503d3d/event/up]
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: [logger]: pkt type = COLLISION_PACKET, count_us = 3672030023
Thu Dec 11 09:51:26 2025 user.debug lora_pkt_fwd[8546]: DEBUG: peek packet with count_us=3670778052 at index 0
Thu Dec 11 09:51:26 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:4535:thread_jit(): lgw_send done on rf_chain 0: count_us=3670778052
Thu Dec 11 09:51:27 2025 user.debug lora_pkt_fwd[8546]: DEBUG: timersync wait result 145
Thu Dec 11 09:51:27 2025 user.info lora_pkt_fwd[8546]: INFO: host/radio[0] time offset=(1765443015 s:867021 us) - drift=1 us
Thu Dec 11 09:51:29 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:29 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:29 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:29 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:31 2025 user.debug lora_pkt_fwd[8546]: PPS check: pps_xticks=0, last_pps_xticks=0, pps_nochange_count=59491, local_pps_ok=0
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]:  ##### 2025-12-11 09:51:33 UTC #####
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ### [UPSTREAM] ###
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # RF packets received by concentrator: 3
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # CRC_OK: 66.67%, CRC_FAIL: 33.33%, NO_CRC: 0.00%
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # RF packets forwarded: 2 (35 bytes)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # PUSH_DATA datagrams sent: 3 (605 bytes)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # PUSH_DATA acknowledged: 100.00%
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ### [DOWNSTREAM] ###
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # PULL_DATA sent: 6 (100.00% acknowledged)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # PULL_RESP(onse) datagrams received: 4 (826 bytes)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # RF packets sent to concentrator: 2 (102 bytes)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # TX errors: 0
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # TX rejected (collision packet): 100.00% (req:142, rej:142)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # TX rejected (collision beacon): 0.00% (req:142, rej:0)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # TX rejected (too late): 0.00% (req:142, rej:0)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # TX rejected (too early): 0.00% (req:142, rej:0)
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ### SX1302 Status ###
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # SX130X counter (INST): 3677929659
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # SX130X time (PPS): 0, offset us 0
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # BEACON queued: 0
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # BEACON sent so far: 0
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # BEACON rejected: 0
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ### [JIT] ###
Thu Dec 11 09:51:33 2025 user.info lora_pkt_fwd[8546]: src/jitqueue.c:453:jit_print_queue(): INFO: [jit] queue is empty
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: #--------
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ### [GPS] ###
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: # GPS sync is disabled
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ### Concentrator[0] temperature: 30 C ###
Thu Dec 11 09:51:33 2025 user.notice lora_pkt_fwd[8546]: ##### END #####
Thu Dec 11 09:51:33 2025 user.debug lora_pkt_fwd[8546]: watchdog wait result 0
Thu Dec 11 09:51:33 2025 user.debug lora_pkt_fwd[8546]: watchdog check past/last tstamp[0]: 3647907941 3677929659
Thu Dec 11 09:51:33 2025 user.info lora_pkt_fwd[8546]: src/lora_pkt_fwd.c:3369:thread_up(): nb_pkt 0 send_report 1
Thu Dec 11 09:51:33 2025 user.info lora_pkt_fwd[8546]:  JSON up: {"stat":{"time":"2025-12-11 09:51:33 UTC","rxnb":3,"rxok":2,"rxfw":2,"ackr":100.0,"dwnb":4,"txnb":2,"temp":30.0}}
Thu Dec 11 09:51:33 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 125
Thu Dec 11 09:51:33 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 125
Thu Dec 11 09:51:33 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:33 2025 daemon.info gwBridge[8423]: Uplink - {"stat":{"time":"2025-12-11 09:51:33 UTC","rxnb":3,"rxok":2,"rxfw":2,"ackr":100.0,"dwnb":4,"txnb":2,"temp":30.0}}
Thu Dec 11 09:51:33 2025 daemon.info gwBridge[8423]: Stats : Protobuf size 46
Thu Dec 11 09:51:33 2025 daemon.info mqttEv[8423]: mqttEvPublish : [[gwBridgeS Mqtt Client]] publish - [46]¥¨êÉFP]
Thu Dec 11 09:51:33 2025 user.info lora_pkt_fwd[8546]: INFO: [up] PUSH_ACK received in 21 ms
Thu Dec 11 09:51:35 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:35 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:35 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:35 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:37 2025 user.debug lora_pkt_fwd[8546]: DEBUG: timersync wait result 145
Thu Dec 11 09:51:37 2025 user.info lora_pkt_fwd[8546]: INFO: host/radio[0] time offset=(1765443015 s:867022 us) - drift=1 us
Thu Dec 11 09:51:40 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:40 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:40 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:40 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:41 2025 user.debug lora_pkt_fwd[8546]: PPS check: pps_xticks=0, last_pps_xticks=0, pps_nochange_count=59501, local_pps_ok=0
Thu Dec 11 09:51:42 2025 user.debug lora_pkt_fwd[8546]: INFO: [MQTT] mqttLogger: Client mqtt-logger-1765387182 sending PINGREQ
Thu Dec 11 09:51:42 2025 user.debug lora_pkt_fwd[8546]: INFO: [MQTT] mqttLogger: Client mqtt-logger-1765387182 received PINGRESP
Thu Dec 11 09:51:45 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:45 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:45 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:45 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:47 2025 user.debug lora_pkt_fwd[8546]: DEBUG: timersync wait result 145
Thu Dec 11 09:51:47 2025 user.info lora_pkt_fwd[8546]: INFO: host/radio[0] time offset=(1765443015 s:867022 us) - drift=0 us
Thu Dec 11 09:51:50 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:50 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Thu Dec 11 09:51:50 2025 daemon.info gwBridge[8423]: Uplink Packet from Gateway ac1f09fffe18503d
Thu Dec 11 09:51:50 2025 user.info lora_pkt_fwd[8546]: INFO: [down] PULL_ACK received in 2 ms
Thu Dec 11 09:51:51 2025 user.debug lora_pkt_fwd[8546]: PPS check: pps_xticks=0, last_pps_xticks=0, pps_nochange_count=59511, local_pps_ok=0
Thu Dec 11 09:51:55 2025 daemon.info gwBridge[8423]: gwBridgeReadCB: Frame size 12
Thu Dec 11 09:51:55 2025 daemon.info gwBridge[8423]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Device log:
DEBUG:0000089023:COMMS:  >> RAK4270 version:3.3.0.17
DEBUG:0000089175:COMMS:  >> UART1 work mode: RUI_UART_NORMAL, 115200, N81
DEBUG:0000089180:COMMS:  >> UART2 work mode: RUI_UART_NORMAL, 115200, N81
DEBUG:0000089188:COMMS:  >> Current work_mode:LoRaWAN, join_mode:OTAA, Multicast
DEBUG:0000089190:COMMS:  >> Initialization OK
DEBUG:0000089190:COMMS: << at+set_config=lora:default_parameters
DEBUG:0000089416:COMMS:  >> OK
DEBUG:0000089418:COMMS: << at+set_config=lora:join_mode:0
DEBUG:0000089421:COMMS:  >> OK
DEBUG:0000089423:COMMS: << at+set_config=lora:class:2
DEBUG:0000089436:COMMS:  >> OK
DEBUG:0000089438:COMMS: << at+set_config=lora:region:EU868
DEBUG:0000089442:COMMS:  >> OK
DEBUG:0000089444:COMMS: << at+set_config=lora:confirm:1
DEBUG:0000089447:COMMS:  >> OK
DEBUG:0000089449:COMMS: << at+set_config=lora:adr:0
DEBUG:0000089452:COMMS:  >> OK
DEBUG:0000089454:COMMS: << at+set_config=lora:dr:4
DEBUG:0000089462:COMMS:  >> OK
DEBUG:0000089464:COMMS: << at+set_config=lora:dutycycle_enable:0
DEBUG:0000089468:COMMS:  >> OK
DEBUG:0000089470:COMMS: << at+set_config=lora:dev_eui:bcfcc644f909e65c
DEBUG:0000089703:COMMS:  >> OK
DEBUG:0000089705:COMMS: << at+set_config=lora:app_eui:bcfcc644f909e65c
DEBUG:0000089931:COMMS:  >> OK
DEBUG:0000089933:COMMS: << at+set_config=lora:app_key:f3fe43d0920ceb7df3d9a3e081
DEBUG:0000090168:COMMS:  >> OK
DEBUG:0000090170:COMMS: << at+set_config=device:restart
DEBUG:0000090204:COMMS:  >> LoRa (R) is a registered trademark or service mark o
DEBUG:0000090207:COMMS:  >> RAK4270 version:3.3.0.17
DEBUG:0000090359:COMMS:  >> UART1 work mode: RUI_UART_NORMAL, 115200, N81
DEBUG:0000090364:COMMS:  >> UART2 work mode: RUI_UART_NORMAL, 115200, N81
DEBUG:0000090372:COMMS:  >> Current work_mode:LoRaWAN, join_mode:OTAA, Multicast
DEBUG:0000090374:COMMS:  >> Initialization OK
DEBUG:0000090376:COMMS: << at+join
DEBUG:0000095738:COMMS:  >> OK Join Success
DEBUG:0000095740:COMMS: Sending an 'is alive' packet.
DEBUG:0000095740:COMMS: << at+send=lora:3:
DEBUG:0000100766:COMMS:  >> ERROR: 95
DEBUG:0000100766:COMMS: Timed out waiting for packet in window RX1.
DEBUG:0000100766:COMMS: Resending 3/5
DEBUG:0000100766:COMMS: Broken backup, cant resend
DEBUG:0000131335:COMMS: LoRa chip timed out, resetting.
Any thoughts?
What are you using on the gateway? Semtech UDP Packet Forwarder, MQTT Forwarder, Gateway Bridge? And which version?
I am using as MQTT Forwarder.
WisGateOS_2.2.15_RAK
But are you using the ChirpStack MQTT Forwarder or the RAK MQTT Forwarder? Have you confirmed it is compatible with v4? In doubt use the gateway UDP forwarder and use the ChirpStack Gateway Bridge (v4 version!) on your server to convert from UDP <> MQTT.
If you are experiencing issues with the internal MQTT Forwarder for ChirpStack v4 of the RAK WisGateOS2 (2.2.15), but when using the Semtech UDP packet-forwarder (compatible) forwarder + ChirpStack Gateway Bridge (v4) does work, then I expect there could be an issue with the MQTT Forwarder implementation by RAK.
As an alternative to using the ChirpStack Gateway Bridge on a server, you could install the ChirpStack MQTT Forwarder package on your gateway using these instructions: https://www.chirpstack.io/docs/chirpstack-mqtt-forwarder/install/rak.html.
Thank you
