Hi!
Thanks for your reply and I think you are right, of course. :-)
There are three GWs forwarding the request and I see now that the first one have "timeSinceGpsEpoch": "0s" wich probably is the cause.
I can also see that the second have a reasonable time in timeSinceGpsEpoch and the third is totally missing timeSinceGpsEpoch.
So I guess we have to look at the GWs. Is this a common problem?
Best regards,
Marcus
"phy_payload": {
"mhdr": {
"f_type": "ConfirmedDataUp",
"major": "LoRaWANR1"
"mic": [
161,
150,
210,
150
"payload": {
"f_port": 6,
"fhdr": {
"devaddr": "xxxxx41a",
"f_cnt": 1,
"f_ctrl": {
"ack": false,
"adr": true,
"adr_ack_req": false,
"class_b": false,
"f_opts_len": 2,
"f_pending": false
"f_opts": [
"LinkCheckReq",
"DeviceTimeReq"
"frm_payload": "7267913454372c3c162310ffaa100101000000b417a9840b794d85b81d5b3a64d978"
"rx_info": [
"channel": 17,
"context": "7ntp3A==",
"crcStatus": "CRC_OK",
"gatewayId": "xxxxxxxxxxx10002",
"gwTime": "2025-12-10T11:24:38.420358+00:00",
"location": {
"altitude": 51,
"latitude": xx.75219,
"longitude": xx.96211
"nsTime": "2025-12-10T11:24:38.343818297+00:00",
"rssi": -100,
"snr": -24,
"timeSinceGpsEpoch": "0s",
"uplinkId": 45918
"context": "AAAAAAAAAAAASAASPnmBNA==",
"gatewayId": "xxxxxxxxxxx10012",
"gwTime": "2025-12-10T11:24:37.420374+00:00",
"location": {
"latitude": xx.76145194203488,
"longitude": xx.97551822662354
"nsTime": "2025-12-10T11:24:38.423157467+00:00",
"rssi": -86,
"snr": -20,
"timeSinceGpsEpoch": "1449401095.420374s",
"uplinkId": 4016623103
"channel": 17,
"context": "i85iBA==",
"gatewayId": "xxxxxxxxxxx10004",
"location": {
"altitude": 64,
"latitude": xx.7629,
"longitude": xx.9216
"nsTime": "2025-12-10T11:24:38.328511970+00:00",
"rssi": -99,
"snr": -20,
"uplinkId": 11679
"tx_info": {
"frequency": 867700000,
"modulation": {
"lora": {
"bandwidth": 125000,
"codeRate": "CR_4_5",
"spreadingFactor": 12
Could you please add a screenshot of the uplink containing the
DeviceTimeReqwith therxInfoelements from the gateway? This contains the time reported by the gateway and I suspect this is the root of the issue.
