Advantech Wise 2410 - FFT
Viewed 93
We are currently working with a WISE-2410 vibration sensor and receiving its FFT data using a generic LoRaWAN gateway and ChirpStack v4 as the LNS. At this stage, we are successfully receiving the eight messages corresponding to the FFT transmission.
However, only the first message of the FFT sequence is correctly interpreted by the decoder configured in ChirpStack. The remaining seven messages return errors during decoding.
Could please confirm if there is any specific configuration or adjustment in ChirpStack (or in the decoder itself) required to correctly process all eight FFT messages? Any technical guidance or example configuration for handling complete FFT data from the WISE-2410 would be greatly appreciated.
