How to set the MCKey for the multicast node and the McNwkSKey and McAppSKey
11
Viewed 159
The following picture shows the Multicast network session key, the Multicast application session key, and the McKey of the nodes that I set myself. However, even after the settings were completed, multicast communication still couldn't be carried out after Time2SessionStart. I would like to know if there are any requirements for the setting of these three keys?
Please note that the MCKey is used to derrive the Multicast McNwkSKey / McAppSKey. Therefore, at the ChirpStack side when creating the multicast-group, you only have to configure the Multicast McNwkSKey / McAppSkey.
Using the Remote Multicast Setup protocol (I assume that is what you are using to make the device aware about the multicast-session), you send the (encrypted) MCKey to the device. The device will use this key to then derrive the Multicast McNwkSKey / McAppSKey using the following scheme:
I have a followup question to this answer. It is entirely possible that I misunderstanding something obvious here, and if so, I apologize in advance.
I understand that McKey is used to derive McNwkSKey and McAppSKey. However, the server has to tell the end device McKey_encrypted in a McGroupSetupReq command, right? How does the server figure out what McKey_encrypted is for this command? On the ChirpStack side, we only tell it McNwkSKey/McAppSKey, and it is not clear to me how one can derive McKey_encrypted given that information without brute forcing it.
The McKey_encrypted is part of the Remote Multicast Setup spec, which is an application-layer protocol. Adding a device to a multicast-group in ChirpStack does not trigger this command, you must sent it yourself. Only in case of FUOTA does ChirpStack send this. I assume in your case, you need to send this command yourself.
