JoinRequest–JoinAccept loop
Viewed 126
This is a repost from the forum, as the original topic didn’t seem to get enough visibility and we’re still experiencing the issue.
Original topic:
https://forum.chirpstack.io/t/lost-join-accept-on-gateway-bridge/25647
Some devices that were working perfectly fine just a few days ago are now stuck in a continuous JoinRequest–JoinAccept loop. Here is one example:
We’ve checked all the available logs (that I could find at least) but haven’t found anything useful—there’s essentially the same information as shown in the web interface. I’d be glad to share the logs if anyone has ideas on how we could debug this further and identify the root cause.
Since we have quite a large number of devices, my initial suspicion was that there aren’t enough resources to process every packet in time. To mitigate this, I added another instance of the Application Server with the Network Server (now running two ChirpStack container replicas). I also installed MQTT forwarders on some of the gateways—originally, a single instance of the Gateway Bridge was running on the server—but unfortunately, this didn’t change anything.
Any tips or suggestions would be greatly appreciated!
Given that you see a JoinAccept in the web-interface means that the gateway did send an acknowledgement of transmission as only on receiving an ack, ChirpStack will show the JoinAccept.
If the ChirpStack Gateway Bridge is running on the gateway, you could try (on the gateway):
sudo tcpdump -AUq -i lo port 1700
If the GW Bridge is running on a VM, then you could try (on the gateway / on the GW Bridge VM):
sudo tcpdump -AUq port 1700
An other option is to use a spectral scanner to see if the gateway is actually transmitting the downlink.
In the instances where I have devices in this join loop state the issue usually arrises from the end device not receiving the join request due to either poor signal or interference. How far apart are the gateway and this device, also out of curiosity what model is the gateway and the end device?
One thing you could try is increasing the transmit power the gateway uses. I think chirpstack defaults to a transmite power of 20 when the default is left in the regional config.
You can edit this in the regional .toml files if you edit the line "downlink_tx_power". Depending on your gateway that value can be pushed much higher (in my image above it is from a tektelic kona-mega gateway, and I have it set for 36dBm which is the absolute max for the US915 region). This setting can significatly improve the range your gateway transmissions will reach. Just make sure you stay within regional specifications, and watch for your gateway to start giving 'TX_POWER' errors in the TX packets/status graph. If that happens you need to lower the tx_power because it has exceeded the gateways ability.
Thank you for the information, it’s very helpful. Unfortunately, the values are already maxed out for my region (in github.com/lrwn/src/region/eu868.rs, get_downlink_tx_power_eirp), but it prompted me to check the configuration on the gateways. As a result, I was able to adjust some settings and gain a few extra dB for certain gateways.
The affected devices are spread across different locations, and some are almost next to the gateways (signal is strong), yet they are still stuck in the JoinRequest–JoinAccept loop. The gateways in question are Kerlink iStation and iFemtoCell.
Since these devices had previously been joined to the network but then went into this join loop, do you know what caused the devices to clear their join state?
Since posting this have you had other devices go into this join loop? If not I would expect a hardware or firmware failure on these particular devices. Is there any way you can replace them with another unit and see if the new one joins. You may have to accept that these devices have a firmware corruption or hardware issue that you will never been able to fix via Chirpstack and the only option is to replace them.
As shown in the figure above, if possible, check the gateway logs or LED lights to see whether the Join Accept LoRa radio message was correctly sent.
