Received http2 header with status: 400, grpc_status:13
Viewed 243
I'm running Chirpstack v4.15.0 on Red Hat Openshift.
I'm trying to use the API with Python and gRPC but I have the following error:
<_InactiveRpcError of RPC that terminated with:
	status = StatusCode.INTERNAL
	details = "Received http2 header with status: 400"
	debug_error_string = "UNKNOWN:Error received from peer  {grpc_message:"Received http2 header with status: 400", grpc_status:13}"
I set the debug level to TRACE but the container wrote only this:
2025-10-22T07:42:53.942963Z DEBUG gRPC{uri=/api.DeviceService/Get}: chirpstack::api: Started processing request
2025-10-22T07:42:53.943003Z INFO gRPC{uri=/api.DeviceService/Get}: chirpstack::api: Finished processing request status="400" latency=53.601µs
Someone can help me to understand where is the error ?
Thanks in advance
Marco
#!/usr/bin/env python3
Legge la configurazione completa di un device in ChirpStack v4 via gRPC API.
Recupera anche le chiavi OTAA direttamente dal server.
import sys
import grpc
from chirpstack_api import api
def main(host, port, api_token, dev_eui):
    server = f"{host}:{port}"
    print(f"Connecting to {server}")
    channel = grpc.insecure_channel(server)
    auth_token = [("authorization", f"Bearer {api_token}")]
    client = api.DeviceServiceStub(channel)
    # --- Legge il device dal server ---
    try:
        print(f"Request info about the device '{dev_eui}'")
        client_response = client.Get(
            api.GetDeviceRequest(dev_eui=dev_eui),
            metadata=auth_token
        device = client_response.device
        print("=== Device ===")
        print(f"Name: {device.name}")
        print(f"DevEUI: {device.dev_eui}")
        print(f"JoinEUI: {device.join_eui}")
        print(f"Description: {device.description}")
        print(f"Application ID: {device.application_id}")
        print(f"Device Profile ID: {device.device_profile_id}")
    except grpc.RpcError as e:
        print(f"Error: {e.details()} (code {e.code()})")
        print(e)
        sys.exit(1)
    # --- Legge le chiavi OTAA dal server ---
    try:
        print(f"Request info about OTAA keys of the device '{dev_eui}'")
        keys_response = client.GetKeys(
            api.GetDeviceKeysRequest(dev_eui=dev_eui),
            metadata=auth_token
        keys = keys_response.device_keys  # <-- attenzione: i valori reali sono dentro device_keys
        print("\n=== Chiavi OTAA ===")
        print(f"AppKey: {keys.app_key}")
        print(f"NwkKey: {keys.nwk_key}")
        print(e)
        sys.exit(1)
    sys.exit(0)
if __name__ == "__main__":
    if len(sys.argv) != 5:
        print(f"Usage: {sys.argv[0]} <HOST> <PORT> <API_TOKEN> <DEVICE_EUI>")
        sys.exit(1)
    host = sys.argv[1]
    port = sys.argv[2]
    api_token = sys.argv[3]
    dev_eui = sys.argv[4]
