ChirpStack Community Support
Questions Tags Users Badges
Error with Downlink to DS3604-Displays
Erik 1
Created Jan 21
Viewed 61
Anyone ever bumped into an error from downlinks that says the following?
Code: DOWNLINK_GATEWAY
Level: ERROR
description: GPS_UNLOCKED
There are 3 different gateways that should be able to send these downlinks. Two UG65-gateways and one Multitech MTCDTIP-L4E1-266A. We are getting the same error on three different Displays.
troubleshooting gateways chirpstack
Share
Related
Devices re-join unless power cycled / intermittently go on and off
Gateway LoRaWAN frames tab not showing any frames
v4.11.1 – Device Profiles page fails: "Error deserializing field 'relay_cad_periodicity': Received more than 2 bytes while decoding an i16"
ADR never sends LinkADRReq despite good SNR margin (stuck at DR0/SF12 for months) - ChirpStack v4.16.2
chirpstack::api::backend: Read from Redis Stream error error=timed out
Chirpstack UDP Forwarder Gets Empty Gateway ID Resulting in Error
Terms of service Privacy policy
Powered by Answer
