ChirpStack 3 with Kona Gateway
Viewed 97
Gateway connects to Chirpstack 4 via MQTT successfully.
Gateway fails to connect to Chirpstack 3 via MQTT.
Gateway connects to Chirpstack 4 via UDP successfully.
  • When Gateway is connected via UDP, Devices fail to join. Chirpstack 3 throws error that device not found in DB.
  • Re-adding devices doesn't help
  • I also tried manually adding device in DB, but it still throws error that device not found.
error="get device error: object does not exist"
