MQTT authentication problem
Viewed 10
I have installed Chirpstack 4.17.0 on Ubuntu 24.xx.
It worked fine, but now I am trying to button down security just a little, and have the following problem : when I enable mosquitto security (disallowing anonymous access and setting a password file), nothing works and the mosquitto-log fills up with :
1783586509: Client d21f3609142423dd disconnected, not authorised.
1783586509: New connection from 127.0.0.1:40228 on port 1883.
1783586509: Client eb7b8e42b842898b disconnected, not authorised.
1783586509: New connection from 127.0.0.1:40234 on port 1883.
1783586509: New connection from 127.0.0.1:40238 on port 1883.
1783586509: Client 4ae9385d7b577d46 disconnected, not authorised.
I HAVE tested the username and password with mosquitto_sub and it works.
/etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml :
  # MQTT authentication.
  [integration.mqtt.auth]
  # Type defines the MQTT authentication type to use.
  # Set this to the name of one of the sections below.
  type="generic"
    # Generic MQTT authentication.
    server="tcp://127.0.0.1:1883"
    username="alftest"
    password="12345"
    /etc/chirpstack/chirpstack.toml:
[integration]
  enabled = ["mqtt"]
  [integration.mqtt]
    server = "tcp://127.0.0.1:1883/"
    json = true
    username = "alftest"
    password = "12345"
Please note that ChirpStack has two connections to the MQTT broker:
  • chirpstack.toml -> MQTT integration
  • region_XXXX.toml -> MQTT connection in the gateway config
You probably missed to configure the credentials in the region_XXXX.toml configuration file.
Yes !!!!
Thank you !!!
That was the solution.
