Gateway Mesh / Rx delay configuration
Viewed 43
We have already contacted you: https://support.chirpstack.io/questions/10010000000000820/gateway-mesh-rx-delay-configuration/10020000000000863
We are still experiencing network latency issues. The device never receives the downstream signal containing the RxTimingSetupReq command because the default delay is too short.
We have managed to increase this delay on the device side, but this solution is neither satisfactory nor sustainable.
Do you have any suggestions for resolving this issue?
Thank you in advance for your help.
Best regards,
