Basic Station Certs Generator
Viewed 67
Howdy everybody, new here but have been enjoying ChirpStack very much for several months now.
I want to talk about Basic Station gateways for a second. I understant there is no CUPS support from CS which is fine and well, but has there been any plan for a more managed approach to TLS certificate generation via CS itself? I recently wrote a program called "CS-Bridge-Guard" which generates client and server certs for Basic Station mTLS and outputs a zip with the ca, cert, and key for the client. As you'll see from the splashscreen below, I have added several other functionalities as well, but want to know if this is something the community would widely benefit from.
Great to see you all here - Mitch
|   ___ ____    ____       _     _                         |
|  / __/ ___|  | __ ) _ __(_) __| | __ _  ___              |
| | |_\___ \   |  _ \| '__| |/ _` |/ _` |/ _ \             |
| | |_ ___) |  | |_) | |  | | (_| | (_| |  __/             |
|  \__|____/   |____/|_|  |_|\__,_|\__, |\___|             |
|              / ___|_   _  __ _ _ |___/| |_               |
|             | |  _| | | |/ _` | '__/ _` |                |
|             | |_| | |_| | (_| | | | (_| |                |
|              \____|\__,_|\__,_|_|  \__,_|                |
|      ------| Keeping Your Certs Safe   |------           |
| Mitch Readinger                              2-19-26     |
What do you want to do?
  1) Status check (certs + service + listener)
  2) Initialize CA (create if missing)
  3) Issue/Update SERVER cert for new public FQDN (install + optional restart)
  4) Provision NEW gateway (issue client cert/key by EUI + export bundle zip)
  5) Update EXISTING gateway (re-issue client cert/key by EUI)
  6) Restart gateway bridge service
  7) Tail gateway bridge logs (Ctrl+C to stop)
  8) Configure paths/options (show or set)
  9) Inventory: search / list / mark installed / set nickname / expiring
 10) Server cert rollback (restore previous lns-server cert/key)
  0) Exit
Enter a number (m=main, q=quit):
Thanks for sharing. Please note that within ChirpStack, it is possible to generate client-certificates for each configured gateway. The process is more or less the same as https://www.chirpstack.io/docs/guides/mosquitto-tls-configuration.html, but in this case you do configure the Gateway Bridge instead of the MQTT forwarder with the server-certificate and CA certificate.
