OTAA activation on two servers simultaneously
Viewed 60
With OTAA, a device can only be registered to one network server at a time, since the session is established through the join process between the device and the server.
Given this limitation, is it possible for the device to be active on two servers simultaneously by using the ChirpStack Multiplexer?
No, also with the multiplexer, this is not possible.
Okay, so that means the multiplexer is only forwarding the raw UDP packets, and the 'second network server' cannot encrypt the messages. So you can only see the messages on the second server within the LoRaWAN frames from the gateway, not under events of the device?
Related
