no internal frame cache for token 0
Viewed 53
I'm testing a connection with an old gateway using Semtech Packet Forwarder 1.0
The uplink messages work fine but I don't receive the downlink messages.
On log of the chirpstack gateway bridge I can read the following message:
error="no internal frame cache for token 0"
According to the spec v1, the PULL_RESP has token=0.
On the code I can see:
if p.ProtocolVersion != ProtocolVersion1 {
		// these two bytes are unused in ProtocolVersion1
		binary.LittleEndian.PutUint16(out[1:3], p.RandomToken)
But I don't find the same check when unmarshall the TX_ACK message.
Could it be a bug ?
I'm using the version of Chirpstack 4.16.2 and the gateway is a very oldest version:
https://github.com/USIWPModule/USI_I-NUCLEO-LRWAN1
Could you please Edit your question with the exact Semtech Packet Forwarder version + ChirpStack Gateway Bridge version you are using?
I have updated your question with the link you shared. However, that is a LoRaWAN module firmware, not a gateway.
