ChirpStack v4.17.0-test.3
Viewed 6
v4.17.0 (in development)
Features
CLI password reset
This release adds a new CLI option to reset passwords, either by prompt stdin or by password file. See CLI commands for more information. (#820)
Secondary NetIDs for roaming
This feature makes it possible to assign secondary NetIDs to a roaming-agreement. This makes it possible to use multiple NetIDs within a single roaming-agreement.
Read-only API keys
This release adds the option to create read-only API keys. If a key is configured as read-only, it is not possible to create, update or delete objects with this key.
Improvements
  • Update Docker base-image to Alpine v3.23.3
  • Update dependencies for API clients.
  • Update React to v19.2 and Antd to v6.1.
  • Improve scheduler concurrency + add new scheduler_lock_duration setting.
  • Misc. UI improvements. (#823, #873)
  • Move from yarn to pnpm as package manager. #874)
  • Add dev_eui filter to list multicast groups API. (#728)
  • Set enabled_uplink_channel_indices on first uplink for ABP devices. (#844)
  • Add PKCE challenge support for OIDC. (#851)
  • Update internal dependencies.
Bugfixes
  • Remove FCnt increment check from get_for_phypayload function. (#813)
  • Remove device_profile_templates import from Python API client. (#842)
  • Fix JS codec / Buffer module unable to import ieee754 module. (#841). Warning: As a side-effect of this fix, strict mode is now enforced by the JS runtime!
  • Fix MQTT integration shared subscription for command subscribe.
  • Remove ws:// option from configfile template in MQTT configuration, as this scheme is (currently) not available. (#741)
  • Fix OIDC user dropdown menu in UI. (#852)
Testing
For testing, please use the Docker image or downloads below:
