Join requests still received from old DevEUI after device reconfiguration
Viewed 58
We encountered an issue with a LoRaWAN device during provisioning and would like to understand the behavior.
Initially, a sensor was registered in ChirpStack with an incorrect DevEUI, which resulted in the error:
Invalid MIC, make sure keys are correct.
Later, the device entry was corrected by adding a new device with the correct DevEUI and AppKey, and the old device entry (with the wrong DevEUI) was deleted from ChirpStack.
However, even after ~10 hours, the device has not joined successfully. When checking the gateway logs and ChirpStack logs, we still see JoinRequest messages coming from the old DevEUI (the one that was deleted).
Some additional details:
  1. The physical device is the same sensor, not a different one.
  2. Only the DevEUI in ChirpStack was corrected.
  3. The AppKey remained the same.
  4. The old device entry was removed after creating the new one.
Our question is:
Why would ChirpStack/gateways still receive JoinRequest messages with the old DevEUI, even though the device entry was deleted and a new device with the correct DevEUI was created?
Could this indicate:
  1. the device firmware still transmitting the old DevEUI,
  2. some caching behavior,
  3. or another possible cause?
Any insights on how to debug or resolve this would be greatly appreciated.
Thank you.
When checking the gateway logs ...
Even if the device does not exist at all in ChirpStack, you will see join-requests in the gateway logs. In normal deployments, this means that it is normal to see join-prequests from devices that are not yours, as the gateway is not able to filter these out (unless you have DevEUI or JoinEUI filters configured on the gateway).
In your case this means that it is the device using that DevEUI in the join-request, not a caching issue at the ChirpStack side. The LoRaWAN frames under gateways will show you exactly what the gateway is receiving.
The LoRaWAN tab of the gateway reports what the gateway is receiving, regardless of the devices you have configured in ChirpStack. If you see an unexpected DevEUI, it is either because your device uses a different DevEUI or the gateway is picking up a device that is not yours (which is not unexpected as devices are not "connected" to a gatewaay, your gateway just reports what it received on the configured frequencies).
Hey @brocaar thanks for the reply. So you mean to say the device which is added now with the correct DevEUI will not report to the gateways !? Then why is the old DevEUI keeps coming ?
