ChirpStack MQTT Forwarder on Dragino: mTLS Connection Fails with v4.3.1
Viewed 68
Configuration with Client Certificates
[mqtt]
  topic_prefix="eu868"
  server="ssl://my.broker.com:18883"
  username=""
  password=""
  ca_cert="/etc/chirpstack-mqtt-forwarder/root_ca.crt"
  tls_cert="/etc/chirpstack-mqtt-forwarder/client.crt"
  tls_key="/etc/chirpstack-mqtt-forwarder/client.key"
  client_id="lorawan-gateway-dragino"
Observed Behavior
The MQTT client is configured, but no connection attempt is made to the broker. Broker logs show no connection attempts from the Dragino's IP.
Comparison: Username/Password with TLS Works
With the following configuration (username/password auth, with TLS), the connection works perfectly:
[mqtt]
  username="chirpstack"
  password="***"
Relevant Log Output (mTLS Configuration)
Starting ChirpStack MQTT Forwarder (version: 4.3.1)
Setting up Semtech UDP Packet Forwarder backend
Binding UDP socket, bind: 0.0.0.0:1700
Retrieving Gateway ID from backend
Received Gateway ID from backend, gateway_id: a84041ffff2b89fa
Setting up MQTT client
Configuring client with TLS certificate, ca_cert: ..., tls_cert: ..., tls_key: ...
add_parsable_certificates processed 129 valid and 0 invalid certs
No further log entries after this – no connection attempt.
Yes, I know I'm using an unusual port here (18883). I want to use different listeners and this shouldn't be a problem, right?
Already Tried
  • ca_chain.crt (root + intermediate CA) instead of root_ca.crt
  • Server URL with IP address instead of hostname
  • Verified full certificate chain on broker
  • Network connectivity confirmed (e.g. nc to broker works)
Is there any known problem with mTLS (cert/key)?
Are you sure 18883 is the correct port number?
Typically:
  • 1883 = MQTT (no encryption)
  • 8883 = MQTT over TLS
Yes, it is the correct port.
I may have chosen a somewhat unfortunate number here, but 18883 is my Mosquitto listener for LoraWAN. This also works with mTLS via other clients (tested with MQTTX, MQTT Explorer, and mosquitto_pub/sub).
I use different listeners to separate my various IoT devices.
I was also able to access the broker from the Dragino via this port using netcat.
