ChirpStack Gateway OS v4.10.0
Viewed 36
v4.10.0
ChirpStack Device Repository
Note: This only applies to images that have ChirpStack pre-installed.
This release adds support for importing device profiles from https://github.com/chirpstack/chirpstack-device-profiles. See also the ChirpStack changelog for v4.16.0. In case you have old device-profile templates, you can migrate these using the following command:
chirpstack -c /var/etc/chirpstack migrate-device-profile-templates
OpenVPN support
This release adds the kmod-tun package for all targets, which is required when installing OpenVPN through the package-repository. (#143)
Updates
  • Update ChirpStack Concentratord to v4.6.0
  • Update ChirpStack MQTT Forwarder to v4.5.1
  • Update ChirpStack UDP Forwarder to v4.3.0
  • Update ChirpStack Gateway Mesh to v4.1.2
  • Update ChirpStack to v4.16.1
Improvements
  • Update to OpenWrt v24.10.5.
