Border gateways sends continuously event/stats messages
Viewed 56
I am facing an issue while registering a Border Gateway on ChirpStack v4, configured to communicate via MQTTS.
The gateway appears to be correctly connected to the MQTT broker, however the broker continuously receives event/stats messages, like the example below:
eu868/gateway/0016c001xxxxxx/event/stats {"gatewayId":"0016c001xxxxxx","time":"2026-01-19T18:44:05.887980733+00:00","metadata":{"concentrator_temp":"36.1875","model":"seeed_wm1302","config_version":"51f74004a9eee1fa","hal_version":"Version: 2.1.0;","mqtt_forwarder_version":"4.4.1","concentratord_version":"4.5.2"},"dutyCycleStats":{"regulation":"ETSI_EN_300_220","window":"3600s","bands":[{"name":"L","frequencyMin":865000000,"frequencyMax":868000000,"loadMax":"36s","loadTracked":"1.559s"},{"name":"M","frequencyMin":868000000,"frequencyMax":868600000,"loadMax":"36s","loadTracked":"3.335s"}]}}
These messages are being received continuously.
Is this an MQTTS configuration issue?
Is it a gateway configuration issue?
Thank you in advance for your help.
Thanks, we did a mistake in the configuration of the gateway and put 0 in the "stat interval". In this cas, stats are published continuously on the MQTT broker.
With 30s as "stat interval", all is OK.
Regards
