ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 923000000, dr: 4
Viewed 92
We are facing an issue in ChirpStack v4 where one AS923-1 gateway with the following log error:
no channels found for this frequency: 923000000
Error
Setup
  • ChirpStack v4
  • Two gateways in the same property
  • Both gateways have:
    Same AS923-1 region
    Same packet-forwarder config
    Same ChirpStack configuration
  • Gateway type: Semtech UDP packet-forwarder
Gateway configuration (affected gateway)
  • board_freq_band: AS923_1
  • Uplink channels: 922.0 – 923.4 MHz
 [network]
 enabled_regions = [
   "as923",
   "as923_2",
   "as923_3",
   "as923_4"
Observation
  • One gateway works correctly and processes uplinks as expected
  • The other gateway (same configuration) logs:
and uplinks are dropped
  • Gateway stats and metrics are received normally for both gateways
  • Issue is isolated to one gateway only
Questions
  1. How does ChirpStack decide which AS923 region to apply per gateway when multiple AS923 variants are enabled?
  2. Is it mandatory to explicitly bind each gateway to a single region (e.g. as923) to avoid this behavior?
  3. Could an incorrect or missing region association cause only one gateway to be evaluated against the wrong AS923 variant, even if configs are identical?
Any guidance on the correct setup for multi-AS923 environments would be appreciated.
Thanks!
Please note that each AS923 variant has a different MQTT topic-prefix. You will find the correct MQTT topic-prefix in each of the region_as923... configuration files (in general, it is the same as the region config-id).
Yes, each gateway must report to the correct MQTT topic, else you get errors like these.
EDIT: In short the error No channel found for frequency means that the gateway is reporting on a channel not expected by ChirpStack. As an example, you would get the same error in EU868 when an uplink is received on 867.1Mhz if this configuration would not be present: https://github.com/chirpstack/chirpstack/blob/master/chirpstack/configuration/region_eu868.toml#L276
In your configuration, make sure that the gateway channels are in sync with the extra-channel config in ChirpStack.
I've updated my answer.
Hey @brocaar, can you check my response to your answer. I couldn't add the image in the comment section.
Hey @brocaar, thanks for your reply.
Both gateways are configured with the same topic_prefix because they operate in the same region (AS923_1). Is using the same topic_prefix for both gateways a potential issue?
