Seeed SenseCAP M2 - image file too large
Viewed 40
I'm trying to follow the directions to setup the SenseCAP M2 but when I download the image from the website to the M2 it tells the file is too large and it won't let me continue. Is there something I should do before staring the SenseCAP M2 to Gateway OS update procedure?
Thanks - Bruce
I got this to work. I did a 'Reset to defaults' under System->Backup/Flash Firmware. After this was complete it seemed to not have any application firwmare so I downloaded the firmware shown under the Gateway OS to SenseCAP M2 instructions on the same page: https://www.chirpstack.io/docs/chirpstack-gateway-os/install/seeed.html. After I did this and repowered the screens via the Webinterface looked different than it previosly did. I'm wondering now what I had loaded on this M2. But after using this new image I could then follow the instructions on that same page for SenseCAP M2 to Gateway OS and this time it followed the process as described. Its now up and talking to the MQTT broker.
