Chirpstack 4 grpc with grpcurl
Viewed 147
i'd like to automate some things via bash scripts. My goto tool in this case is "grpcurl".
My server runs in docker (chirpstack/chirpstack:4.15).
The following command:
grpcurl -import-path "$PROTO_PATH" \
        -proto as/external/api/organization.proto \
        "$CHIRPSTACK_API_URL" list
returns:
api.OrganizationService
Am i right to assume that grpc communication is wokring?
The next command:
grpcurl -d "$(cat <<EOF
  "organization": {
    "name": "$TENANT_NAME",
    "display_name": "$TENANT_DESC",
    "can_have_gateways": true
EOF
-H "Authorization: Bearer $CHIRPSTACK_API_TOKEN" \
"$CHIRPSTACK_API_URL" api.OrganizationService.Create
fails with the message:
ERROR:
  Code: Unimplemented
  Message:
Now i have tried some variations, including one that suggested "api.OrganizationService/Create" but none of the commands worked.
Am i missing something?
Thank you so much! I didn't realize i had old proto files. Now it works.
