ChirpStack 3 with Kona Gateway
Viewed 60
Gateway connects to Chirpstack 4 via MQTT successfully.
Gateway fails to connect to Chirpstack 3 via MQTT.
Gateway connects to Chirpstack 4 via UDP successfully.
  • When Gateway is connected via UDP, Devices fail to join. Chirpstack 3 throws error that device not found in DB.
  • Re-adding devices doesn't help
  • I also tried manually adding device in DB, but it still throws error that device not found.
error="get device error: object does not exist"
What is the reason you would want to use v3 instead of v4? Please note that v3 is no longer being updated.
To reproduce production issues. Production is on Chirpstack 3 currently.
For the v3 communication, are you using the ChirpStack Gateway Bridge v3.x.y?
