Pie chart rendering issues in web-interface
Viewed 69
I have installed Chirpstack (chirpstack-concentratord, chirpstack-gateway-bridge and chirpstack on Raspberry Pi CM4 under Ubuntu v.18), some times it worked fine, but now I see that UI circles decrease over time, then disappear altogether. But I am receiving data, the server works. I used it on port 8082 because port 8080 already used by other application.
What to do?
When you say that the pie charts are decreasing in size, is that without reloading the page? E.g. if you reload the page, is the issue solved? I think this is a rendering issue. Any hints how to reproduce would be welcome (including browser version).
This happens after each reloading, also in Incognito mode, it takes 9 second for decreasing from normal size to zero.
Just now I found that this is in Chrome browser only. I tried also to turn off all the extentions, hard reload with cache cleaning. Microsoft Edge has no this problem. Also I don't see the problem with Chrome on global website with SSL certificate.
I call Chirpstack from Node-React Application.
I have not idea how to reproduce. If I will have new info, I inform you.
I have Chrome Version 140.0.7339.210 (Official Build) (64-bit)
