ChirpStack Gateway OS v4.8.3
Viewed 77
v4.8.3
Bugfixes
Raspberry Pi: fix failing boot after upgrade
This release fixes an issue with the Raspberry Pi images that could cause the bootprocess of the Raspberry Pi to fail after an upgrade. For more details about this issue, please see:
In case you are affected by this issue and you have access to the terminal (e.g. USB keyboard + HDMI display) you could try the following command to restore the Raspberry Pi: firstboot && reboot. firstboot will normally reset the overlayfs containing the configuration, but as in case of this issue OpenWrt fails to mount it, this will cause OpenWrt to re-create the overlayfs and restore the configuration backup to it after the reboot.
