ChirpStack Gateway Mesh v4.1.0
Viewed 62
v4.1.0
Features
Events / commands
Refactor Mesh heartbeat
This refactors the Gateway Mesh heartbeat payload into a more generic Mesh Event payload, which can be used by both "known" and "proprietary" event types. The first implemented "known" type is the heartbeat. While this refactor is not backwards compatible and requires ChirpStack MQTT Forwarder v4.4+, the backwards incompatibility does not affect the functioning of the Gateway Mesh itself.
Proprietary events
This release adds configuration options to periodically send Relay events. These events can generated by commands that are periodically executed. See the configuration section for more information.
Proprietary commands
Next to events, this release also makes it possible to remotely execute commands on the Relay gateways, by using MQTT. See the configuration section for more information.
ZMQ API
This aligns the Concentratord ZMQ API interface with the ChirpStack Concentratord v4.5+. Please make sure to update to this Concentratord version or later. For Border Gateways, please make sure to also update the ChirpStack MQTT Forwarder to v4.4 or later.
Improvements
  • Make Relay ID configurable.
Bugfixes
  • Add tx_power to AU915 (region_au915.toml) configuration example. (#67)
