I'm trying to enable unicast Class B on an EU868 network.
The full MAC handshake completes successfully — PingSlotInfoReq → PingSlotInfoAns, PingSlotChannelReq → PingSlotChannelAns — but ChirpStack never publishes beacon frames to the gateway's MQTT command topic (gateway//command/#), and the device never achieves beacon lock.
Stack:
- ChirpStack v4, region EU868;
- Gateway: Kerlink iFemtoCell Evolution (lorad → lorafwd → chirpstack-gateway-bridge → MQTT). This gateway has no GPS time, we forward the NTP instead. This is a test phase only, so it should be fine;
- Device profile: Class B enabled, ping slot DR3, 32s periodicity, frequency 869525000 Hz;
- region_eu868.toml: ping_slot_dr=3, ping_slot_frequency=0 (default frequency)
What I verified:
- Uplinks and regular downlinks for Class A work fine over MQTT;
- Monitoring gateway//command/# shows no beacon frames ever, even after the MAC handshake completes;
- Device remains CLASS_A in ChirpStack despite PingSlotInfoAns being sent;
Is there any additional configuration required to trigger beacon scheduling in ChirpStack v4? Could the chirpstack-gateway-bridge (Semtech UDP backend) be the issue?
Thanks.
