I have a US915 LoRaWAN setup that was working a few days ago and has degraded. Looking for help diagnosing.
Setup:
- Device: Arduino MKR WAN 1310 using MKRWAN library, US915, OTAA, MAC v1.0.3
- Gateway: RAK2243 HAT on Raspberry Pi 4 (Debian 12 Bookworm), running RAK's
ttn-gatewaypacket forwarder fromrak_common_for_gatewayinstall. SX1301 concentrator. - Network Server: ChirpStack 4.18.0 on a separate Raspberry Pi (Debian 13 Trixie), with chirpstack-gateway-bridge and mosquitto on the same Pi.
- Distance: Bench device about 40 ft from the gateway, indoor, with walls between.
- Both ends configured for US915 sub-band 2 (channels 8-15). Device firmware uses explicit
enableChannel(8..15)+disableChannelfor the rest. Gatewayglobal_conf.jsonshows the matching 8 multi-SF channels at 903.9-905.3 MHz on sub-band 2.
Was working a few days ago: clean joins, regular uplinks, downlinks delivered in ~60s. No firmware or gateway config changes since then.
Current symptom — directional asymmetry:
The gateway IS hearing the device's uplinks (sometimes successfully, sometimes CRC_FAIL), but the device is NOT receiving downlinks from the gateway.
Specifically:
- Device serial monitor: "Attempting OTAA join... Join FAILED. Retrying in 30s..." in a loop
- Gateway journal: receives JoinRequest packets with strong signal (RSSI -55 to -65 dBm, SNR +9 dB) when they arrive
- ChirpStack UI: shows JoinRequest received, generates JoinAccept downlink in the LoRaWAN Frames tab
- Gateway journal: shows the JoinAccept being scheduled for downlink transmission (PULL_RESP received, txpk packet logged with correct frequency 923.9 MHz, SF7BW500, codr 4/5)
- Device: never sees the JoinAccept, stays in retry loop
Reception rate at the gateway (uplink side):
Of the device's once-per-minute transmissions, the gateway concentrator hears roughly 1-2 in 5. Of those it hears, about half have CRC_OK, the rest CRC_FAIL. When CRC_OK, RSSI is excellent (-55 to -65 dBm). When CRC_FAIL, RSSI is similar — strong signal, just decoded bits failing CRC.
What I have tried:
- Verified antennas are physically tight, vertical, factory-supplied
- Verified
lorawan_public: truein gateway config (sync word 0x34) - Verified firmware's
enableChannel(8..15)config - Power-cycled the gateway Pi (hard unplug 10s, replug)
- Tried
delay(2000)beforemodem.begin(US915)in firmware setup (no change) - Reset the device multiple times
- Verified ChirpStack frame-counter validation is disabled (so stale FCnt isn't blocking)
- Reset gateway service (
systemctl restart ttn-gateway)
None of the above resolved it.
What I want to understand:
- Why downlinks aren't reaching the device despite being scheduled correctly on the gateway side. RX window timing? Device receive path issue? Something specific about RAK2243 + MKR WAN 1310 + ChirpStack?
- Why CRC_FAIL on roughly half of received uplinks when RSSI is excellent. Local interference signature? Hardware degradation? Something else?
- Has anyone seen this specific pattern (working → degrading → uplinks-work-but-downlinks-fail) on a stable setup?
Logs available:
I can paste full gateway journal output, ChirpStack LoRaWAN Frames screenshots, and device serial monitor output if helpful. Will respond to anyone offering specific things to check.
Thanks for any insight. I am well out over my ski's here!!
I do not have the answer to your question, but timing is critical. Too much drift and the the device might miss the RX window. The CRC_FAIL on half of the uplinks is not normal I think. You could try to reproduce the same with an other device or gateway.
