Mosquitto authentication
Viewed 121
Hi all,
I'm new to chirpstack.
I have installed Chirpstack trhrough the docker-compose.yml file given as template.
Everything works correctly.
Now I am trying to configure Mosquitto authentication.
I followed the guide here and created a password file.
Then I disabled anonymous mqtt usage.
And then I edited the configuration/chirpstack/chirpstack.toml file and changes the mqtt section like this:
[integration]
  enabled=["mqtt"]
  [integration.mqtt]
    server="tcp://$MQTT_BROKER_HOST:1883/"
    json=true
    username="my_user"
    password="my_password"
    # Quality of service level
    # 0: at most once
    # 1: at least once
    # 2: exactly once
    qos=2
However, when I restart the docker compose I get plenty of authentication errors like these:
chirpstack-gateway-bridge-basicstation-1  | time="2026-03-19T12:48:10.828133609Z" level=error msg="integration/mqtt: connection error" error="not Authorized"
chirpstack-gateway-bridge-1               | time="2026-03-19T12:48:10.911842045Z" level=warning msg="[client]   status is already disconnected" module=mqtt
mosquitto-1                               | 1773924490: New connection from 172.30.0.6:39914 on port 1883.
mosquitto-1                               | 1773924490: Client auto-6328DF75-213E-90B9-A125-9476131A8BDA [172.30.0.6:39914] disconnected: not authorised.
I have tried two times to recreate the password file for mosquitto, as I thought I maybe had botched the password during creation, but I always get the same errors.
Any suggestions?
Thank you in advance
Cris
Thank you once more @brocaar!
Thanks to your suggestion to use mosquitto_sub, I was able to find out that the user/password was actually working, and that there were instead some problems with variable expansion.
Now everything is working as expected!
Cris
Please note the service in the logs, it is not ChirpStack failing, it is the Gateway Bridge. You probably did not configure this service yet with the username / password.
Have you restarted the Mosquitto service? If that is the case: try to narrow down the issue: use e.g. mosquitto_sub to make sure the issue is with the Mosquitto.
Thank you very much @brocaar !
However, that was just a little excerpt of the output: unfortunately ChirpStack is failing, too.
You were right though, that I did not configure correctly the Gateway Bridge.
So I have added the credentials to the configuration/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml file, too.
Unfortunately, nothing changed :'-(
