We created a new Chirpstack Gateway Bridge Service to implement a new region configuration that limits the data rate of the installation. However, after creating the service and migrating the packet forwarder port of the gateways, we are losing frames in the device log.
We can see that the gateway is receiving the frames, but the device is missing them.
Most of the devices are sending in DR5, but the new region configuration has a maximum DR3.
I'm getting an error message when uploading photos to this post.
Ultimately, we only want to limit the DR of the devices because, at DR5, we are missing some frames due to the coverage limit. However, due to the high frequency between the frames, they cannot go lower than DR4 or DR3. That's why we created the new region configuration to force them to get the LinkADRreq command.
What could be the issue, and is our approach correct?
Best regards,
