Gateway configuration
Viewed 14
Hi
I am using LoRa E5 mini as my end device and RASPBERRYPI 4B model is configured as LoRaWAN Gateway using WM1302 LoRaWAN Gateway Module.My region is in865 My end device support the below frequency channels:
AT+ CH?
+CH: 3; 0,865062500,DR0,DR5; 1,865402500,DR0,DR5; 2,865985000,DR0,DR5;
So based my end device frequency channel configuration,is my gateway configuration corect
"SX130x_conf": {
    "com_type": "SPI",
    "com_path": "/dev/spidev0.0",
    "lorawan_public": true,
    "clksrc": 0,
    "antenna_gain": 0, /* antenna gain, in dBi */
    "full_duplex": false,
    "fine_timestamp": {
        "enable": false,
        "mode": "all_sf" /* high_capacity or all_sf */
    "sx1261_conf": {
        "spi_path": "/dev/spidev0.1",
        "rssi_offset": 0, /* dB */
        "spectral_scan": {
            "enable": false,
            "freq_start": 867100000,
            "nb_chan": 8,
            "nb_scan": 2000,
            "pace_s": 10
        "lbt": {
            "enable": false,
            "rssi_target": -70, /* dBm */
            "channels":[ /* 16 channels maximum */
                { "freq_hz": 867100000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 867300000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 867500000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 867700000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 867900000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 868100000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 868300000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 868500000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                { "freq_hz": 869525000, "bandwidth": 125000, "scan_time_us": 5000, "transmit_time_ms": 4000 },
                { "freq_hz": 868300000, "bandwidth": 250000, "scan_time_us": 128,  "transmit_time_ms": 400 }
    "radio_0": {
        "enable": true,
        "type": "SX1250",
        "freq": 865985000,
        "rssi_offset": -215.4,
        "rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
        "tx_enable": true,
        "tx_freq_min": 865000000,
        "tx_freq_max": 867000000,
        "tx_gain_lut":[
            {"rf_power": 12, "pa_gain": 0, "pwr_idx": 15},
            {"rf_power": 13, "pa_gain": 0, "pwr_idx": 16},
            {"rf_power": 14, "pa_gain": 0, "pwr_idx": 17},
            {"rf_power": 15, "pa_gain": 0, "pwr_idx": 19},
            {"rf_power": 16, "pa_gain": 0, "pwr_idx": 20},
            {"rf_power": 17, "pa_gain": 0, "pwr_idx": 22},
            {"rf_power": 18, "pa_gain": 1, "pwr_idx": 1},
            {"rf_power": 19, "pa_gain": 1, "pwr_idx": 2},
            {"rf_power": 20, "pa_gain": 1, "pwr_idx": 3},
            {"rf_power": 21, "pa_gain": 1, "pwr_idx": 4},
            {"rf_power": 22, "pa_gain": 1, "pwr_idx": 5},
            {"rf_power": 23, "pa_gain": 1, "pwr_idx": 6},
            {"rf_power": 24, "pa_gain": 1, "pwr_idx": 7},
            {"rf_power": 25, "pa_gain": 1, "pwr_idx": 9},
            {"rf_power": 26, "pa_gain": 1, "pwr_idx": 11},
            {"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
    "radio_1": {
        "enable": true,
        "type": "SX1250",
        "freq": 866785000,
        "tx_enable": false
    "chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
    "chan_multiSF_0": { "enable": true, "radio": 0, "if": -400000, "freq": 865062500 },
            "chan_multiSF_1": { "enable": true, "radio": 0, "if": -200000, "freq": 865402500 },
            "chan_multiSF_2": { "enable": true, "radio": 0, "if": 0,       "freq": 865985000 },
            "chan_multiSF_3": { "enable": true, "radio": 1, "if": -400000, "freq": 866185000 },
            "chan_multiSF_4": { "enable": true, "radio": 1, "if": -200000, "freq": 866385000 },
            "chan_multiSF_5": { "enable": true, "radio": 1, "if": 0,       "freq": 866585000 },
            "chan_multiSF_6": { "enable": true, "radio": 1, "if": 200000,  "freq": 866785000 },
            "chan_multiSF_7": { "enable": true, "radio": 1, "if": 400000,  "freq": 866985000 },
    "chan_Lora_std":  {"enable": true, "radio": 1, "if": -200000, "bandwidth": 250000, "spread_factor": 7,
                       "implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit>        "chan_FSK":       {"enable": true, "radio": 1, "if":  300000, "bandwidth": 125000, "datarate": 50000}
"gateway_conf": {
    "gateway_ID": "0016C001F1111CA3",
    /* change with default server address/ports */
    "server_address": "192.168.0.101",
    "serv_port_up": 1700,
    "serv_port_down": 1700,
    /* adjust the following parameters for your network */
    "keepalive_interval": 10,
    "stat_interval": 30,
    "push_timeout_ms": 100,
    /* forward only valid packets */
    "forward_crc_valid": true,
    "forward_crc_error": false,
    "forward_crc_disabled": false,
    /* GPS configuration */
    "gps_tty_path": "",
    /* GPS reference coordinates */
    "ref_latitude": 0.0,
    "ref_longitude": 0.0,
    "ref_altitude": 0,
    /* Beaconing parameters */
    "beacon_period": 0,
    "beacon_freq_hz": 869525000,
    "beacon_datarate": 9,
    "beacon_bw_hz": 125000,
    "beacon_power": 14,
    "beacon_infodesc": 0
between do i need to enable LBT?
At a quick glance, that looks correct to me.
AT+ CH?
Please note that these are the mandatory channels, these can be extended by the LNS / ChirpStack. Please see the Regional Parameters specification for more information about this.
