How to make /SX1302_LoRaWAN_Gateway_HAT working with ChirpStack
Viewed 103
Subject: Gateway "Never Seen" in ChirpStack v4 despite MQTT messages being received
Setup Description:
Hardware: Raspberry Pi 5.
OS: Debian Bookworm.
Gateway: Waveshare SX1302 LoRaWAN Gateway HAT.
Architecture: SX1302 HAL (Packet Forwarder) -> ChirpStack MQTT Forwarder (installed as service) -> Dockerized ChirpStack v4 Stack.
The Problem: My Mosquitto broker is successfully receiving messages from the gateway in the expected topics (eu868/gateway/0016c001f1054d5e/...). However, the ChirpStack Web UI still shows the gateway as "Never Seen".
Current Configurations:
  1. ChirpStack MQTT Forwarder (chirpstack-mqtt-forwarder.toml)
# Logging settings.
[logging]
  level="info"
  log_to_syslog=false
# MQTT settings.
[mqtt]
  # Prefixo da região (Obrigatório para o ChirpStack v4)
  topic_prefix="eu868"
  # JSON deve estar a FALSE (ChirpStack v4 usa binário)
  json=false
  # --- LINHA CRÍTICA ADICIONADA ---
  # Define explicitamente que a linguagem é Protobuf
  marshaler="protobuf"
  # Endereço do Mosquitto (como está no Docker na mesma máquina, localhost serve)
  server="tcp://127.0.0.1:1883"
  # Deixar utilizador e password vazios se o Mosquitto permitir anónimos
  username=""
  password=""
  qos=0
  clean_session=false
  client_id=""
  keep_alive_interval="30s"
  ca_cert=""
  tls_cert=""
  tls_key=""
  reconnect_interval="30s"
# Backend configuration.
# Aqui definimos que vamos receber dados do Packet Forwarder "antigo" (UDP)
[backend]
  enabled="semtech_udp"
  [backend.filters]
    forward_crc_ok=true
    forward_crc_invalid=false
    forward_crc_missing=false
    dev_addr_prefixes=[]
    join_eui_prefixes=[]
  # Configuração da "Ponte" UDP
  [backend.semtech_udp]
    # Ouve na porta 1700 (onde o lora_pkt_fwd envia os dados)
    bind="0.0.0.0:1700"
    time_fallback_enabled=false
# Gateway metadata configuration.
[metadata]
  [metadata.static]
  [metadata.commands]
# Executable commands.
[commands]
# Callback commands.
[callbacks]
  on_mqtt_connected=[]
  on_mqtt_connection_error=[]
  1. Main ChirpStack Server (chirpstack.toml)
  [logging]
level = "info"
[postgresql]
dsn = "postgres://chirpstack:chirpstack@postgres/chirpstack?sslmode=disable"
[redis]
url = "redis://redis:6379"
[network]
net_id = "000000"
[api]
bind = "0.0.0.0:8080"
secret = "changeme"
[integration.mqtt]
server = "tcp://mosquitto:1883"
json = true
[[regions]]
name = "eu868"
common_name = "EU868"
config_file = "/etc/chirpstack/region_eu868.toml"
3. Region Configuration (region_eu868.toml)
# This file contains an example EU868 configuration.
[[regions]]
  # ID is an user-defined identifier for this region.
  id = "eu868"
  # Description is a short description for this region.
  description = "EU868"
  # Common-name refers to the common-name of this region as defined by
  # the LoRa Alliance.
  # User-defined region information.
  # This information will be displayed on top of the region page in then
  # ChirpStack web-interface. For example, it can contain information about
  # how users should connect their gateways when using this region (e.g. MQTT
  # end-point, MQTT topic prefix, TLS configuration etc). Markdown syntax can
  # be used for formatting.
  user_info = ""
  # Gateway configuration.
  [regions.gateway]
    # Force gateways as private.
    # If enabled, gateways can only be used by devices under the same tenant.
    force_gws_private = false
    [regions.gateway.backend]
      # The enabled backend type.
      enabled = "mqtt"
      # MQTT configuration.
        # Topic prefix.
        # The topic prefix can be used to define the region of the gateway.
        # Note, there is no need to add a trailing '/' to the prefix. The trailing
        # '/' is automatically added to the prefix if it is configured.
        topic_prefix = "eu868"
        # Shared subscription name.
        # In case there are multiple ChirpStack instances sharing the same
        # subscription name, then the MQTT broker will deliver a gateway event
        # only to one subscriber. In case you have a production and
        # test-environment connected to the same MQTT broker, make sure that
        # each environment has its own subscription name, for example:
        # chirpstack_prod and chirpstack_tst.
        share_name = "chirpstack"
        username = ""
        password = ""
        # Quality of service level
        # 0: at most once
        # 1: at least once
        # 2: exactly once
        qos = 0
        # Clean session
        clean_session = false
        # Client ID
        # broker. A client id must be no longer than 23 characters. If left blank,
        # a random id will be generated by ChirpStack.
        client_id = ""
        # Keep alive interval.
        # This defines the maximum time that that should pass without communication
        # between the client and server.
        keep_alive_interval = "30s"
        ca_cert = ""
        tls_cert = ""
        # TLS key file (optional)
        tls_key = ""
    # Gateway channel configuration.
    # Note: this configuration is only used in case the gateway is using the
    # ChirpStack Concentratord daemon. In any other case, this configuration
    # is ignored.
    [[regions.gateway.channels]]
      frequency = 868100000
      bandwidth = 125000
      modulation = "LORA"
      spreading_factors = [7, 8, 9, 10, 11, 12]
      frequency = 868300000
      bandwidth = 125000
      modulation = "LORA"
      frequency = 868500000
      bandwidth = 125000
      modulation = "LORA"
      frequency = 867100000
      bandwidth = 125000
      modulation = "LORA"
      frequency = 867300000
      bandwidth = 125000
      modulation = "LORA"
      frequency = 867500000
      bandwidth = 125000
      modulation = "LORA"
      frequency = 867700000
      bandwidth = 125000
      modulation = "LORA"
      frequency = 867900000
      bandwidth = 125000
      modulation = "LORA"
      bandwidth = 250000
      modulation = "LORA"
      spreading_factors = [7]
      frequency = 868800000
      bandwidth = 125000
      modulation = "FSK"
      datarate = 50000
  # Region specific network configuration.
  [regions.network]
    # surrounded gateways.
    installation_margin = 10
    # RX window (Class-A).
    # Set this to:
    # 0: RX1 / RX2
    # 1: RX1 only
    # 2: RX2 only
    rx_window = 0
    # RX1 delay (1 - 15 seconds).
    rx1_delay = 1
    # RX1 data-rate offset
    rx1_dr_offset = 0
    # RX2 data-rate
    rx2_dr = 0
    # RX2 frequency (Hz)
    rx2_frequency = 869525000
    rx2_prefer_on_rx1_dr_lt = 0
    # Prefer RX2 on link budget.
    rx2_prefer_on_link_budget = false
    # Downlink TX Power (in dBm EIRP)
    # be used.
    downlink_tx_power = -1
    # ADR is disabled.
    adr_disabled = false
    # Minimum data-rate.
    min_dr = 0
    # Maximum data-rate.
    max_dr = 5
    # Rejoin-request configuration (LoRaWAN 1.1)
    [regions.network.rejoin_request]
      # Request devices to periodically send rejoin-requests.
      enabled = false
      # The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
      # uplink messages. Valid values are 0 to 15.
      max_count_n = 0
      # The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
      # seconds. Valid values are 0 to 15.
      # 0  = roughly 17 minutes
      # 15 = about 1 year
      max_time_n = 0
    # Class-B configuration.
    [regions.network.class_b]
      # Ping-slot data-rate.
      ping_slot_dr = 3
      # Ping-slot frequency (Hz)
      # set this to 0 to use the default frequency plan for the configured region
      ping_slot_frequency = 0
    # Below is the common set of extra channels. Please make sure that these
    # channels are also supported by the gateways.
    [[regions.network.extra_channels]]
      min_dr = 0
      max_dr = 5
      min_dr = 0
      max_dr = 5
      min_dr = 0
      max_dr = 5
      min_dr = 0
      max_dr = 5
      min_dr = 0
      max_dr = 5
  1. Mosquitto config
   persistence true
persistence_location /mosquitto/data/
log_dest file /mosquitto/log/mosquitto.log
listener 1883
allow_anonymous true
5 - docker compose file - docker-compose.yml
version: "3.9"
services:
  chirpstack:
    image: chirpstack/chirpstack:4
    container_name: chirpstack
    command: -c /etc/chirpstack
    ports:
      - "8080:8080"
    restart: unless-stopped
    volumes:
      - ./config/chirpstack:/etc/chirpstack
    depends_on:
      - postgres
      - redis
      - mosquitto
    environment:
      - MQTT_BROKER_HOST=mosquitto
      - REDIS_HOST=redis
      - POSTGRESQL_HOST=postgres
  postgres:
    image: postgres:14-alpine
    container_name: chirpstack-postgres
    environment:
      POSTGRES_DB: chirpstack
      POSTGRES_USER: chirpstack
      POSTGRES_PASSWORD: chirpstack
    volumes:
      - agrosas_postgres_data:/var/lib/postgresql/data
      - ./config/postgresql/initdb:/docker-entrypoint-initdb.d
    healthcheck:
      test: ["CMD-SHELL", "pg_isready -U chirpstack"]
      interval: 10s
      timeout: 5s
      retries: 5
  redis:
    image: redis:7-alpine
    container_name: chirpstack-redis
    volumes:
      - agrosas_redis_data:/data
  mosquitto:
    image: eclipse-mosquitto:2
    container_name: chirpstack-mosquitto
    ports:
      - "1883:1883"
    volumes:
      - ./config/mosquitto:/mosquitto/config
      - agrosas_mosquitto_data:/mosquitto/data
      - agrosas_mosquitto_log:/mosquitto/log
volumes:
  agrosas_redis_data:
Troubleshooting performed:
Verified that mosquitto_sub shows uplink traffic on eu868/gateway/0016c001f1054d5e/event/stats.
Confirmed that Gateway ID in the Web UI matches the MQTT topic exactly.
ChirpStack logs show Setting up gateway backends for the different regions but no errors regarding MQTT connection.
waveshare/sx1302_hal_rpi5-master/packet_forwarder
/test_config.json
    "SX130x_conf": {
        "com_type": "SPI",
        "com_path": "/dev/spidev0.0",
        "lorawan_public": true,
        "clksrc": 0,
        "antenna_gain": 0, /* antenna gain, in dBi */
        "full_duplex": false,
        "fine_timestamp": {
            "enable": false,
            "mode": "all_sf" /* high_capacity or all_sf */
        "sx1261_conf": {
            "spi_path": "/dev/spidev0.1",
            "rssi_offset": 0, /* dB */
            "spectral_scan": {
                "enable": false,
                "freq_start": 867100000,
                "nb_chan": 8,
                "nb_scan": 2000,
                "pace_s": 10
            "lbt": {
                "enable": false,
                "rssi_target": -70, /* dBm */
                "channels":[ /* 16 channels maximum */
                    { "freq_hz": 867100000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867300000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867500000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867700000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 867900000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 868100000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 868300000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 868500000, "bandwidth": 125000, "scan_time_us": 128,  "transmit_time_ms": 400 },
                    { "freq_hz": 869525000, "bandwidth": 125000, "scan_time_us": 5000, "transmit_time_ms": 4000 },
                    { "freq_hz": 868300000, "bandwidth": 250000, "scan_time_us": 128,  "transmit_time_ms": 400 }
        "radio_0": {
            "enable": true,
            "type": "SX1250",
            "freq": 867500000,
            "rssi_offset": -215.4,
            "rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
            "tx_enable": true,
            "tx_freq_min": 863000000,
            "tx_freq_max": 870000000,
            "tx_gain_lut":[
                {"rf_power": 12, "pa_gain": 0, "pwr_idx": 15},
                {"rf_power": 13, "pa_gain": 0, "pwr_idx": 16},
                {"rf_power": 14, "pa_gain": 0, "pwr_idx": 17},
                {"rf_power": 15, "pa_gain": 0, "pwr_idx": 19},
                {"rf_power": 16, "pa_gain": 0, "pwr_idx": 20},
                {"rf_power": 17, "pa_gain": 0, "pwr_idx": 22},
                {"rf_power": 18, "pa_gain": 1, "pwr_idx": 1},
                {"rf_power": 19, "pa_gain": 1, "pwr_idx": 2},
                {"rf_power": 20, "pa_gain": 1, "pwr_idx": 3},
                {"rf_power": 21, "pa_gain": 1, "pwr_idx": 4},
                {"rf_power": 22, "pa_gain": 1, "pwr_idx": 5},
                {"rf_power": 23, "pa_gain": 1, "pwr_idx": 6},
                {"rf_power": 24, "pa_gain": 1, "pwr_idx": 7},
                {"rf_power": 25, "pa_gain": 1, "pwr_idx": 9},
                {"rf_power": 26, "pa_gain": 1, "pwr_idx": 11},
                {"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
        "radio_1": {
            "enable": true,
            "type": "SX1250",
            "freq": 868500000,
            "tx_enable": false
        "chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
        "chan_multiSF_0": {"enable": true, "radio": 1, "if": -400000},
        "chan_multiSF_1": {"enable": true, "radio": 1, "if": -200000},
        "chan_multiSF_2": {"enable": true, "radio": 1, "if":  0},
        "chan_multiSF_3": {"enable": true, "radio": 0, "if": -400000},
        "chan_multiSF_4": {"enable": true, "radio": 0, "if": -200000},
        "chan_multiSF_5": {"enable": true, "radio": 0, "if":  0},
        "chan_multiSF_6": {"enable": true, "radio": 0, "if":  200000},
        "chan_multiSF_7": {"enable": true, "radio": 0, "if":  400000},
        "chan_Lora_std":  {"enable": true, "radio": 1, "if": -200000, "bandwidth": 250000, "spread_factor": 7,
                           "implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit_coderate": 1},
        "chan_FSK":       {"enable": true, "radio": 1, "if":  300000, "bandwidth": 125000, "datarate": 50000}
    "gateway_conf": {
        "gateway_ID": "0016c001f1054d5e",
        /* change with default server address/ports */
        "server_address": "127.0.0.1",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        /* adjust the following parameters for your network */
        "keepalive_interval": 10,
        "stat_interval": 30,
        "push_timeout_ms": 100,
        /* forward only valid packets */
        "forward_crc_valid": true,
        "forward_crc_error": false,
        "forward_crc_disabled": false,
        /* GPS configuration */
        "gps_tty_path": "/dev/ttyS0",
        /* GPS reference coordinates */
        "ref_latitude": 0.0,
        "ref_longitude": 0.0,
        "ref_altitude": 0,
        /* Beaconing parameters */
        "beacon_period": 0,
        "beacon_freq_hz": 869525000,
        "beacon_datarate": 9,
        "beacon_bw_hz": 125000,
        "beacon_power": 14,
        "beacon_infodesc": 0,
    "servers": [
        "gateway_ID": "0016C001F1054D5e",
        "serv_enabled": true
    "debug_conf": {
        "ref_payload":[
            {"id": "0xCAFE1234"},
            {"id": "0xCAFE2345"}
        "log_file": "loragw_hal.log"
Hi jaime lopes
Can you share Packet forwarder logs?
Last log of chirpstack-mqtt-forwarder -n 200
Jan 23 17:44:53 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:53.715Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 2360524291, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:44:56 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:56.852Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 23158, remote: 127.0.0.1:38122
Jan 23 17:44:56 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:56.852Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 23158 remote: 127.0.0.1:38122
Jan 23 17:44:56 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:56.852Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 1135807357, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:44:57 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:57.143Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 25390, remote: 127.0.0.1:38122
Jan 23 17:44:57 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:57.143Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 25390 remote: 127.0.0.1:38122
Jan 23 17:44:57 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:57.143Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 4098565729, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:44:58 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:58.267Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 40755, remote: 127.0.0.1:38122
Jan 23 17:44:58 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:58.267Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 40755 remote: 127.0.0.1:38122
Jan 23 17:44:58 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:58.267Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 4132385255, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:44:59 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:59.317Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PULL_DATA received, random_token: 39625, remote: 127.0.0.1:40910
Jan 23 17:44:59 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:59.317Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PULL_ACK, random_token: 39625, remote: 127.0.0.1:40910
Jan 23 17:44:59 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:59.410Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 12902, remote: 127.0.0.1:38122
Jan 23 17:44:59 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:59.410Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 12902 remote: 127.0.0.1:38122
Jan 23 17:44:59 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:44:59.410Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 652438043, topic: eu868/gateway/0016c001f1054d5e/even>
Jan 23 17:45:00 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:00.272Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 46861, remote: 127.0.0.1:38122
Jan 23 17:45:00 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:00.272Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 46861 remote: 127.0.0.1:38122
Jan 23 17:45:00 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:00.272Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 1709274261, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:45:04 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:04.423Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 22577, remote: 127.0.0.1:38122
Jan 23 17:45:04 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:04.423Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 22577 remote: 127.0.0.1:38122
Jan 23 17:45:04 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:04.423Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 4226386412, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:45:07 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:07.700Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 23203, remote: 127.0.0.1:38122
Jan 23 17:45:07 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:07.700Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 23203 remote: 127.0.0.1:38122
Jan 23 17:45:07 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:07.700Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 1931850305, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:45:09 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:09.123Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 23845, remote: 127.0.0.1:38122
Jan 23 17:45:09 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:09.123Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 23845 remote: 127.0.0.1:38122
Jan 23 17:45:09 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:09.123Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending gateway stats event, topic: eu868/gateway/0016c001f1054d5e/event/stats
Jan 23 17:45:09 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:09.321Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PULL_DATA received, random_token: 5893, remote: 127.0.0.1:40910
Jan 23 17:45:09 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:09.321Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PULL_ACK, random_token: 5893, remote: 127.0.0.1:40910
Jan 23 17:45:19 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:19.521Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PULL_DATA received, random_token: 59736, remote: 127.0.0.1:40910
Jan 23 17:45:19 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:19.521Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PULL_ACK, random_token: 59736, remote: 127.0.0.1:40910
Jan 23 17:45:27 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:27.786Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 54366, remote: 127.0.0.1:38122
Jan 23 17:45:27 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:27.786Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 54366 remote: 127.0.0.1:38122
Jan 23 17:45:27 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:27.786Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 880406253, topic: eu868/gateway/0016c001f1054d5e/even>
Jan 23 17:45:29 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:29.524Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 45739, remote: 127.0.0.1:38122
Jan 23 17:45:29 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:29.524Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 45739 remote: 127.0.0.1:38122
Jan 23 17:45:29 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:29.524Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 1415906541, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:45:29 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:29.721Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PULL_DATA received, random_token: 50893, remote: 127.0.0.1:40910
Jan 23 17:45:29 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:29.721Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PULL_ACK, random_token: 50893, remote: 127.0.0.1:40910
Jan 23 17:45:31 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:31.802Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 4436, remote: 127.0.0.1:38122
Jan 23 17:45:31 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:31.803Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 4436 remote: 127.0.0.1:38122
Jan 23 17:45:31 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:31.803Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 367464583, topic: eu868/gateway/0016c001f1054d5e/even>
Jan 23 17:45:33 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:33.312Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 33294, remote: 127.0.0.1:38122
Jan 23 17:45:33 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:33.312Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 33294 remote: 127.0.0.1:38122
Jan 23 17:45:33 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:33.313Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 375943343, topic: eu868/gateway/0016c001f1054d5e/even>
Jan 23 17:45:33 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:33.521Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 16756, remote: 127.0.0.1:38122
23T17:45:33.521Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 16756 remote: 127.0.0.1:38122
Jan 23 17:45:33 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:33.521Z INFO [chirpstack_mqtt_forwarder::mqtt] Sending uplink event, uplink_id: 1797516837, topic: eu868/gateway/0016c001f1054d5e/eve>
Jan 23 17:45:34 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:34.123Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] PUSH_DATA received, random_token: 15649, remote: 127.0.0.1:38122
Jan 23 17:45:34 AgroSas chirpstack-mqtt-forwarder[5076]: 2026-01-23T17:45:34.123Z INFO [chirpstack_mqtt_forwarder::backend::semtech_udp] Sending PUSH_ACK, random_token: 15649 remote: 127.0.0.1:38122
