I'm confused on what applications use what TOML files
Viewed 82
I've loaded Chirpstack onto a Raspberry PI runing Pi OS following the instructions for a Debian/Ubuntu device. I'm now trying to modify the TOML files but I see mention of MQTT within chirpstack.toml and within the specific region toml files. For the application/network portion of Chirpstack which TOML file do I need to modify so that this has access to the MQTT data being published by the gateway. This isn't clear to me.
The global MQTT integration (for device communication) configuration can be found in:
  • chirpstack.toml
The MQTT configuration for gateway communication can be found in:
  • region_XXXXX.toml
  • Example: region_eu868.toml
Please note that while it is possible to use different MQTT brokers for the MQTT integration and gateway communication, you can use the same MQTT broker.
