Question about the meaning of “txack” in Events (downlink confirmed vs only sent)
Viewed 120
Hello ChirpStack support team,
I have a question about how to interpret the “txack” flag/signal shown in Events related to downlinks.
When a downlink is sent and I see txack in the Events, does that mean:
  • the end node actually received the downlink (device-level confirmation), or
  • only that the network server sent the downlink (e.g., queued/emitted to the gateway), with no guarantee the end node received it?
If possible, could you also point out which specific event I should look at to distinguish “sent” vs “received/confirmed by the device,” and whether this depends on using a confirmed downlink and/or Class A/C?
There are two events you might be interested in:
  • txack: This indicates that a queued downlink was sent. There is no guarantee that it was received by the device.
  • ack: In case the downlink was enqueued as confirmed: true, then the ack event indicates that it was acknowledged (or not) by the end-device.
Thank you!
