Setting a Tektelic Kona gateway transmission power using the Chirpstack MQTT forwarder
Viewed 71
Hello Chirpstack community,
We are using a Tektelic Kona Macro gateway in combination with the Chirpstack MQTT Forwarder. This is installed on the gateway and the default Tektelic MQTT forwarder is disabled.
In principle this setup works fine, but we realized that due to our attena setup, we are exceeding the allowed EIRP tranmission limits from the gateway to end devices.
Unbelievably, we were informed by Tektelic that you cannot configure the maximum transmission power on the gateway itself and if you are using another network server, it should be done from the network server side.
I found the downlink_tx_power parameter in the region configuration file, but that seems to be applied to all gateways then.
Another possibility seems to be the Chirpstack Concentratord, but this does not seem to be supported out-of-the-box for Tektelic gateways.
In the Chirpstack MQTT Forwarder I also do not seem to find any reference to a way to regulate the transmission power.
Could someone please help me out here?
I believe for this reason, Semtech added this configuration to the Semtech UDP Packet Forwarder. In my opinion, the Tektelic packet-forwarder should provide the same:
https://github.com/Lora-net/sx1302_hal/blob/master/packet_forwarder/global_conf.json.sx1257.EU868#L7
https://github.com/Lora-net/packet_forwarder/blob/master/lora_pkt_fwd/global_conf.json#L16
The Tektelic gateways are not supported, as the HAL used by Tektelic is (unfortunately) not open-source.
Sorry, I suspect I should have posted my response to your answer here ...
What I'm saying is that it exists in the Semtech implementation. Tektelic might not have implemented this configuration. However, I do believe this is something for the gateway to manage as it is the gateways responsibility to stay within legal limits. ChirpStack does not provide an option to compensate for antenna gain.
Apologies for my late reply @brocaar, I somehow did not get a notification.
Can I somehow configure the Semtech implementation outside of Tektelic? If yes, where can I find more info on their implementation? I guess this is then not the right forum anymore?
Hi Orne,
Thanks a lot for the fast response!
I actually tried the global_conf.json approach, but I suspect I placed the file in the wrong directory on the gateway.
I placed global_conf.json in /etc/chirpstack-mqtt-forwarder but it did not seem to have any affect. But I get it now that this is actually not an MQTT Forwarder configuration, but rather that of the Semtech UDP Packet Forwarder.
Where should I place this configuration file and how can I check that it was applied? Or is there an existing one somewhere that I need to update?
the global_conf.json have no option to directly configure the transmission power.
This requires modifying the C code and global_conf.json so that the 2 work together to control the transmission power.
To make it more convenient to use, a transmit power dropdown menu needs to be provided on the web configuration page, as shown in the figure below.
Hi rimelink,
Thanks for the answer, but I am afraid I have no idea to which web configuration page you are referring.
The web configuration page from the Tektelic Kona gateway is very simplistic and looks completely different from the one you posted?
Yes, this is the LoRaWAN Gateway from www.rimelink.com. They added the WEB+global_conf.json+C to control the transmission power of the Gateway. Please refer to the 《Rime LoRaWAN Outdoor Gateway Manual》 http://www.rimelink.com/nd.jsp?id=60#_np=105_315
I'm downvoting this answer, as we are talking about a complete different gateway in this case.
