WebUI Default Number of displayed Records
Viewed 44
Dears,
Wouldn't it be nice to have these defaults in the chirpstack.toml file instead of being hardcoded (Chirpsatck v4.15.0)?
**src/config.rs** (line 241):
impl Default for Monitoring {
    fn default() -> Self {
        Monitoring {
            bind: "".to_string(),
            api_request_log_max_history: 10,
            backend_interfaces_log_max_history: 10,
            meta_log_max_history: 10,
            gateway_frame_log_max_history: 10,
            device_frame_log_max_history: 10,
            device_event_log_max_history: 10,
            per_gateway_frame_log_max_history: 10,
            per_device_frame_log_max_history: 10,
            per_device_event_log_max_history: 10,
            per_gateway_frame_log_ttl: Duration::from_secs(60 * 60 * 24 * 31), // 31 days
            per_device_frame_log_ttl: Duration::from_secs(60 * 60 * 24 * 31),
            per_device_event_log_ttl: Duration::from_secs(60 * 60 * 24 * 31),
Please note that impl Default implementations are implementing the default values, unless specificied (in the chirpstack.toml) configuration. So yes, you can configure these values in the chirpstack.toml file. See the [monitoring] section here: https://www.chirpstack.io/docs/chirpstack/configuration.html.
Please note that this does not change the number of items displayed in the UI. This value is currently set to 10 in code.
Thank you very much @Brocaar
