ChirpStack v4.15.0
Viewed 290
v4.15.0
Features
Blynk integration
This release adds a new integration with the Blynk IoT platform.
InfluxDB v3
This release updates the InfluxDB integration to also support InfluxDB v3.
Move FCntUp out of device-session
This moves the f_cnt_up field out of the device-session blob and stores it as a separate column in the device table. By doing this, it is no longer needed to wrap the uplink validation into a transaction and lock the device records matching the uplink DevAddr, as we can update the record with a where f_cnt_up = OLD_F_CNT_UP and check that the updated record-count != 0. Removing the transaction and locking the device-records matching the uplink DevAddr avoids a potential deadlock situation that might occur when multiple devices are sharing the same DevAddr.
The f_cnt_up will be automatically migrated from the device-session into the f_cnt_up device column at runtime.
Improvements
  • Add flush_queue option to Enqueue API method.
  • Add configuration option to flatten json log output. (#759)
  • Update Docker Compose dependency versions (Mosquitto, PostgreSQL, Redis, RabbitMQ and Kafka versions).
  • Update internal dependencies.
  • Cleanup dead code + fix clippy warnings.
  • Move dependency versions into [workspace.dependencies] of Cargo.toml (such that versions can be managed at a single place).
Bugfixes
  • UI: Fix setting gateway last-seen to undefined. (#75)
  • Fix setting TX Info for OTAA join-accept such that RX2 can be prioritized over TX1.
