Gateway reconnection after upgrading Gateway Bridge to v4.1.0
Viewed 66
So, after upgrading Chirpstack Gateway Bridge to latest version (v4.1.0), all the gateways are reconnecting.
We are seeing it throught MQTT connection on topic eu868/gateway/+/state/conn.
We are using Semtech UPD and the default configuration for gateway bridge.
Is there any new configuration parameter we should add in order to avoid this?
Thanks for reporting. I can confirm there is an issue in v4.1.0 which was caused by https://github.com/chirpstack/chirpstack-gateway-bridge/pull/238, but which was until now never released. I'll push a bugfix release shortly. Next time, please also do post some log-output. It usually speeds up the debugging process :)
