Github source for RPI 4B
5
Viewed 121
I am planning to add USB modem support for Gateway OS.
Currently I am using RPI 4B image
But I do not see it in the Github list, there is no BCM2711 listed.
Could someone advice where to find it?
Thanks
Raspberry Pi 2/3/4 all use the same configuration. You will find it in the _bcm2709 directories (full- includes ChirpStack + Node-RED, base- is just the packages needed to run the RPi as a LoRa gateway).
You need to custom build the chirpstack gateway os image by enabling USB Drivers
Hello you say create a personalized image but can you explain how to do it besides openvpn also does not work, why are the packages not all included at least for powerful rpi from 3 b+ for example?
